twin turbo manifold made in to single
gtb
Hi just curious can you put a plate on the passenger side were the turbo was block it off
And just change the up pipe on the driver side to a single is that possible ? Will it effect
Power than just a standard one I got a set of extractors but I don't like the noise they make.cheers
The passenger side will be pretty ugly flow wise . But in all reality its no worse than the drivers side when all the exhaust is going to the primary turbo .
The drivers side end of the manifold and the centre piece are same between twin turbo and single turbo .
Ive got the 3 bits you can have if u want . Theyre in chch . Dunno where u are .
