Gauge Pod
Hi All,
I've recently done some mods to my v7 STI (TBE, Fuel Pump, Tune etc).
So happens my clock decided to stop working, so I thought it would be a perfect place to put in a gauge pod cluster.
Any recommendations on which ones to get and from where?
I'm quite interested in the recessed look, similar to this:
http://www.scoobyworld.co.uk/catalog/product_info.php?products_id=1536
Also any recommendations on what type of gauges to get, obvious one would be Boost... Maybe Oil Pressure? Exhaust Gas Temperature?
Any info would be appreciated.
Looks like the ATI/Defi are the better brands for fit and finish.
This one would give a recessed but fit, but as Scoobydoo mentioned the visor helps with reflections:
http://www.ebay.com/itm/GAUGE-POD-SUBARU-IMPREZA-WRX-STI-01-07-52MM-/271962297985?hash=item3f52375681:g:ck0AAOSwqu9U0qLm&vxp=mtr
Also what is a good brand of gauge? Mechanical or Electronic?
Electronic, definitely. Also be sure you get the right pod size to fit your gauges. You don't want to get the above pod, if your gauges are 60mm hahaha. Or figure out what pod you are getting first, then get the right size gauges to suit. It's probably easier that way.
 boon said:
Just a casual exactly 2 years between posts?
Really? Hah! I thought it was shorter. Oh well.
With regards to 52/60 sizing, the ATI one can be modified to take either size, but once you move to 60 it's a permanent modification iirc
Edited by MercuryFree
Thanks guys,
I've looked at the ATI gauge pod on ebay and the cheapest I can get to NZ is like 280nz...
I would like to run the Defi gauges and managed to get a BF boost gauge off a mate. Did not realise that I also need a control unit which will cost another $250.
Now assuming I get all the kit, this is going to set me back a good $1200 (if not more) just for gauges... No thanks Jeff.
I am a noob when it comes to gauges so excuse my lack of knowledge.
I think I'm just gonna keep it simple and get a boost gauge and mount it on the pillar, looking at this prosport gauge off TM:
http://www.trademe.co.nz/motors/car-parts-accessories/performance/gauges/auction-1055713356.htm
Any other recommendations are welcome :-)
Depending on how many gauges you are including in that, the Defi gear isn't cheap new. $400 a gauge in shops. There's a set of 4 gauges and control unit for $1300 on Trademe... that's an indicative price. Sets of 3 normally go for about 900-1000.
