juddering clutch when cold
when driving my 2000 gtb when driving the car slightly cold taking if I try to take off without giving it any revs the whole car judders really violently. Im not sure if its a serious problem I should look at, because if I warm up the car fully then drive it is fine or if I ride the clutch it is also fine. anyone experienced this before or can anyone share some knowledge?
Pretty common. It just means that your flywheel is a bit uneven. The reality is, unless you are prepared to spend big money money on a new clutch and getting the flywheel machined, then you just have to live with it.
No. It's just a result of using it. You will find pretty much any manual car will get something similar to this over time. A bit like having shudder in your brakes, just that the flywheel is a bit harder to get to than your brake rotors, so it's no small job to get it machined. You are looking around $600 labour alone. So the general idea would be to put a new clutch in while it all apart. That way you don't have to do it all again.
  • Similar Content
