• Announcements
    • 1randomkiwi
      ClubSub Forum Updates   13/03/19
      Important forum upgrades are coming up which may mean the www.ClubSUB.org.nz forums will be temporarily unavailable.   Check out our Official Facebook Page for more updates.   www.facebook.com/ClubSubNZ
RAYDEO
faq
Check Engine Light Codes - MY1989 to MY2000
2 posts in this topic
How to Read Trouble Codes From the ECU
On the gauge cluster, to the top left there are a few idiot lights which are not on under normal driving conditions.  One of these lights reads 'check engine.'  This light comes on when the ECU detects a fault in one of the many electronic components from which it receives signals and to which it transmits signals.  If the ECU recognizes a problem while the car is on, the 'check engine' light will be constantly illuminated.  If it has detected a problem in the past, but the problem which it detected no longer exists, the light will be out.  However, the ECU will store a record of the faults it has detected in the past until they are cleared deliberately or unintentionally.  To read any current or past faults, the 'check engine' light will flash in a sort of Morse code, which we can decipher.
Underneath the steering column is a wide rectangular piece of plastic, the same color as the dash, which has a tray marked 'TRAY.'  This large piece is held to the underside of the dash with a bunch of screws.  Remove these screws and remove the plastic piece.  Now there will be a bunch of wires for you to see.  To the left of the steering column (at least in left hand drive cars) somewhere probably tucked away will be a bundle of wires with two pairs of electrical connectors which are disconnected.  One is black and connects one wire to one wire, the other is green and roughly 'T' shaped, this one also connects one wire to one wire.  With the car turned completely off, connect the black connector.  Next, turn the ignition to 'ON' but do not start the car.  The idiot lights in the dash will come on, and some may go out after a few moments.  Watch the 'check engine' light and maybe have something you can write on to remember the codes.  If there is a fault code in the ECU, the 'check engine' light will begin to flash in a particular manner.  The codes range in number from 11 to 52, so we know that they all will be two digits.  To signify the tens place of the number, the 'check engine' light will flash a long (1.2 seconds) flash.  The single digit will be a short (.2 seconds) flash.  Each flash within the same code will be separated by .3 seconds.  Each error code will be separated by 1.8 seconds.  Don't bother trying to time all these, just watch the light and you will begin to understand.  Once the ECU has flashed all stored codes, it will loop through and repeat them.  Now, for example, you see two long flashes followed by two short flashes.  This means you have a code number 22.  By looking at the following chart, we see that 22 is the code for the knock sensor.  Once you have read and recorded all faults, turn the ignition off and disconnect the black connector.
    If you have done the above procedure, you will likely wonder what the green T-shaped connectors are for.  These are for a more active code reading procedure called D-check mode in the Subaru manuals.  Start with both connectors disconnected, start the engine, allow it to warm up, then turn it off.  Next, connect the test mode connectors (green T-shape).  Turn ignition to ON position without turning on engine.  At this point if the check engine light does not come on, it is faulty and must be fixed before continuing.  Depress accelerator pedal to floor, return to half throttle and hold for two seconds, then release.  Start the engine.  Now the light can blink in two different ways.  If everything checks out so far, it will blink to indicate a number 01, 02, 03, 04, 05, 06, 07, or 08.  If a problem is already detected, it will blink according to the chart below.  Either way, your next step will be to drive the car with the test mode connectors connected.  You must drive over 7 mph for at least one minute, and shift up to 4th gear if you have a manual tranny.  Now, either you will discover your trouble codes, or you will have none.
    To erase trouble codes from the computer (without resorting to the infamous battery disconnect dance), repeat the above procedure exactly, but connect both the green and black connectors at the appropriate time.
Trouble Code Table
Trouble
Code
Item Contents of Diagnosis Fail-Safe Operation Non-
Turbo
Turbo
11 crank angle sensor No signal entered from crank angle sensor, but signal (corresponding to at least one rotation of the crank) entered from cam angle sensor none X    X
12 starter switch Abnormal signal emitted from starter switch Turns starter signal switch OFF X    X
13 cam angle sensor No signal entered from cam angle sensor, but signal (corresponding to at least two rotations of cam) entered from crank angle sensor none X    X
14 Injector #1 Fuel injector inoperative (Abnormal signal emitted from monitor circuit) none X    X
15 Injector #2 Fuel injector inoperative (Abnormal signal emitted from monitor circuit) none X    X
16 Injector #3 Fuel injector inoperative (Abnormal signal emitted from monitor circuit) none X    X
17 Injector #4 Fuel injector inoperative (Abnormal signal emitted from monitor circuit) none X    X
21 Water temperature sensor Abnormal signal emitted from water temperature sensor Adjusts water to a specific temperature, maintains radiator fan "ON" to prevent overheating X    X
22 Knock sensor Abnormal voltage produced in knock sensor monitor circuit Sets in regular fuel map and retards ignition timing X    X
23 Air flow sensor Abnormal voltage input entered from air flow sensor Controls the amount of fuel (injected) in relation to engine speed and throttle sensor position X    X
24 Air control valve Air control valve inoperative (Abnormal signal produced in monitor circuit) Prevents abnormal engine speed using "fuel cut" in relation to engine speed, vehicle speed, and throttle sensor position X    X
31 Throttle sensor Abnormal voltage input entered from throttle sensor Sets throttle sensor's voltage output to a fixed value X    X
32 Oxygen sensor Oxygen sensor inoperative  none X    X
33 Vehicle speed sensor Abnormal voltage input entered from vehicle speed sensor Sets vehicle speed signal to a fixed value X    X
35 Canister purge solenoid valve Solenoid valve inoperative none X    X
41 A/F learning control Faulty learning control function none X    X
42 Idle switch Abnormal voltage input entered from idle switch Judges OFF operation X    X
44 Duty solenoid valve
(Wastegate control)
Duty solenoid valve inoperative none      X
45 Atmospheric pressure sensor Faulty sensor Sets sensor to 760 mmHg X
45 Pressure sensor and pressure exchange solenoid valve Faulty sensor or pressure exchange solenoid valve inoperative Prevents abnormal supercharging pressure using "fuel cut" in relation to engine load      X
49 Air flow sensor Use of improper air flow sensor none X    X
51 Neutral switch Abnormal signal entered from neutral switch none X    X
51 Inhibitor switch Abnormal signal entered from inhibitor switch none X    X
52 Parking switch Abnormal signal entered from parking switch none X    X
1 person likes this
Share this post
Link to post
53 Antenna
53 Anti-Quick Operation Mode
53 Communication Error (Time Over)
53 EGI Control Module EEPROM
53 IMM Circuit Failure (Except Antenna Circuit)
53 IMM Control Module EEPROM
53 Key Communication Failure
53 Reference Code Incompatibility
53 Use of Unregistered Key
54 Air Intake System
55 EGR Valve Lift Sensor
56 EGR System
57 Canister Control System
58 Air Control System
61 Air Suction Control Solenoid Valve
62 Exhaust Manifold Valve Negative Pressure Control Solenoid
64 Relief Valve Control Solenoid Valve 1
64 Relief Valve Control Solenoid Valve 2
65 Differential Pressure Sensor
66 Twin Turbocharger System(H)
66 Twin Turbocharger System(S)
66 Twin Turbocharger System(T)
66 Two Stage Twin Turbocharger System
67 Exhaust Manifold Valve Positive Pressure Control Solenoid
68 Turbocharging Pressure Control Output Signal #2
71 Shift Solenoid Valve
72 Shift Solenoid #2 Circuit
73 Low Clutch Timing Solenoid Circuit
74 Brake Clutch Timing Solenoid Circuit Malfunction
75 Line Pressure Duty Solenoid Circuit
76 Brake Clutch Pressure Duty Solenoid Circuit Malfunction
77 Lock-Up Duty Solenoid Circuit
78 Tiptronic Solenoid System
79 Transfer Clutch Duty Solenoid Circuit
81 Torque Up Control Valve
85 Charger System Circuit Malfunction
86 CAN (Communication System)
87 Variable Induction Solenoid Valve Circuit Malfunction
88 Fuel Pump Circuit Malfunction
89 VVT Systems (L)
89 VVT Systems (R)
91 TCS Relief Valve
92 Electrical Generation Control Signal Circuit Malfunction
93 Vehicle Speed Sensor #1 Circuit
94 Lateral G Sensor Signal Circuit Malfunction
2 people like this
Share this post
Link to post
  • Similar Content
    • By aaronpnz
      Man, this car is getting annoying.
      What does it mean when CEL & Traction lights are on solid, and cruise control flashes?
      I have checked the codes and I get P0037 as a result.
      It's still hunting a bit at lights, and almost stalls when stopping at times, but seems to be fine at power.
      *shrugs* don't want to spend more money on this thing, might be time to get rid of it maybe.
    • By Fl0W
      Hey Guys, sorry if this is in the wrong place or somebody has a similar post but I've got a number of check engine fault codes on my 2001 BH9 Legacy 250S EJ25 (always run on 95 petrol) they are P0390, P0365 and I did have a P0130 code which might've been before I replaced the O2 sensor post cat. The other 2 codes, which I believe both relate to the camshaft position sensor. It seems to be the case because when the car is at operating temp it loves to dip very low on idle sputtering and stuttering, loss of power and almost dying, etc. I ended up buying a new camshaft position sensor from supercheap and I've replaced it with the one that lives on the passenger side towards the front of the engine near the engine oil filler tube.
      But I've still got the same codes after resetting and I've tried a lot of other things like injector cleaner and I've cleaned the throttle body replaced air filter added (mbl8 oil additive I think?) oilange with filter every 10k km and all that jazz. It also has some type of tick along the whole rev range, to me it sounds like it's coming from the top end on the passenger side. Other than that the car runs mint when it feels like being normal but it guzzles fuel like crazy, pretty much almost 15-17 litres /100km around town.  Sorry about the novel I just wrote but I'm out of ideas and I am a student so any help would be much appreciated!
    • By Johnnynz
      Based on the APPLIED MODEL number on you VIN plate you should be able to find out, your exact model type.
      Sample (BG5C Legacy)
      And a GC8
      The 7 digit "applied model" code found on the vehicle identification plate inside the engine bay is decoded in the following way.
      Series code G=Impreza S=Forester B=Legacy etc. Body type F=Wagon C=Sedan Engine type 8=2.0L Turbo Year code A=MY93 B=MY94 C=MY95&96 D=MY97 (facelift) E=MY98 F=MY99 G=MY00 Number of doors 2=2 door coupe 4=4 door saloon 5=5 door wagon/hatch Model type 8=WRX 7=RA type E=Sti D=Sti Type R & RA  Transmission D=5 Speed Manual AWD P=4 Speed Automatic AWD
      Hit CTRL + F Buttons in your browser to open the search function, type your Applied Model Code into the search bar and find your vehicle type.
      All information comes from the Subaru Impreza WRX Sports Parts Catalogue
      Dates
      Model of Impreza
      Applied Model
      Option Codes
      Engine type
      Power (PS)
      Shift type
      Transmission Type
      Comment
      11/92 - 09/93
      WRX
      GC8A48D
      BX
      BJ
      EJ
      EF
      EJ20G DW1HD
      EJ20G DW1HE
      EJ20G DW1HE
      EJ20G DW1HE
      240
      Manual
      TY752VB3AA
      First Impreza Turbo
      WRX type RA
      GC8A47D
      EJ20G DW1HJ
      240
      Manual
      TY752VB3BA
      10/92 - 08/93
      WRX
      GC8B48D
      BX
      BJ
      EJ
      EF
      EJ20G DW1HD
      EJ20G DW1HE
      EJ20G DW1HE
      EJ20G DW1HE
      240
      Manual
      TY752VB3AA
      10/93 - 08/94
      WRX
      GC8B48P
      BJ
      EJ
      EG
      EF
      EJ20G DX1NE
      EJ20G DX1NE
      EJ20G DX1NE
      EJ20G DX1NE
      240
      Auto
      TZ102YB3AA
      TZ102YB3AA
      TZ102YB3AA
      TZ102YB3AA
      WRX type RA
      GC8B47D
      EJ20G DW1HJ
      240
      Manual
      TY752VB3DA
      WRX
      (STi Version)
      GC8B48D
      BX
      BJ
      EJ
      EF
      61C
      EJ20G DW2HD
      EJ20G DW2HE
      EJ20G DW2HE
      EJ20G DW2HE
      EJ20G DW2PE
      250
      Manual
      TY752VB3CA
      TY752VB3CA
      TY752VB3CA
      TY752VB3CA
      TY752VB3CA
      First appearance of STi, modified from production WRX
      WRX
      GF8B58D
      PJ
      MJ
      MF
      62C
      EJ20G DX1NE
      EJ20G DX1NE
      EJ20G DX1NE
      EJ20G DX2RE
      220
      Manual
      TY752VB3CA
      TY752VB3CA
      TY752VB3CA
      TY752VB3CA
      First appearance of 5 door
      WRX
      GF8B58P
      PJ
      MJ
      MF
      EJ20G DX1NE
      EJ20G DX1NE
      EJ20G DX1NE
      220
      Auto
      TZ102YB3AA
      TZ102YB3AA
      TZ102YB3AA
      WRX - SA
      GF8B58P
      PJ
      MJ
      MF
      MC
      EJ20G DX1NE
      EJ20G DX1NE
      EJ20G DX1NE
      EJ20G DX1NE
      220
      Auto
      TZ102YB3AA
      TZ102YB3AA
      TZ102YB3AA
      TZ102YB3AA
      Auto transmission fitted after production
      WRX - SA (STI)
      GF8B58D
      BX
      BJ
      MJ
      MF
      EJ20G DW1ND
      EJ20G DW1NE
      EJ20G DW1NE
      EJ20G DW1NE
      250
      Manual
      TY752VB3CA
      TY752VB3CA
      TY752VB3CA
      TY752VB3CA
      As per WRX STi 4 door, modified from production
      09/94 - 08/95
      WRX
      GC8C48D
      BX
      BJ
      EJ
      EF
      BG
      EJ20G DW4HD
      EJ20G DW4HE
      EJ20G DW4HE
      EJ20G DW4HE
      EJ20G DW4HE
      260
      Manual
      TY752VB3FA
      TY752VB3FA
      TY752VB3FA
      TY752VB3FA
      TY752VB4AA
      WRX V-LIMITED
      GC8C48D
      65
      EJ20G DW5HE
      Manual
      TY752VB4AA
      WRX type RA
      GC8C47D
      EJ20G DW4HJ
      260
      Manual
      TY752VB3EA
      WRX type RA STi Version
      GC8C47D
      61C
      EJ20G DW4PJ
      275
      Manual
      TY752VB3EA
      Modified from production WRX
      WRX
      GF8C58D
      PJ
      MJ
      MF
      PG
      EJ20G DW4NE
      EJ20G DW4NE
      EJ20G DW4NE
      EJ20G DW5NE
      Manual
      TY752VB3FA
      TY752VB3FA
      TY752VB3FA
      TY752VB4AA
      WRX
      GF8C58P
      PJ
      MJ
      MF
      MC
      PG
      EJ20G DX4NE
      EJ20G DX4NE
      EJ20G DX4NE
      EJ20G DX4NE
      EJ20G DX5NE
      220
      Auto
      TZ102YB3BA
      TZ102YB3BA
      TZ102YB3BA
      TZ102YB3BA
      TZ102YB3BA
      09/95 - 08/96
      WRX
      GC8C48D
      260
      Manual
      WRX type RA
      GC8C47D
      260
      Manual
      WRX STi Version 2
      GC8C4ED
      BJC
      EJ20G DW5HE
      275
      Manual
      TY752VB4AA
      First full production STi
      WRX STi Version 2 555
      GC8C4ED
      BKC
      EJ20G DW5PE
      275
      Manual
      TY752VB4AA
      Special edition Our Car
      WRX type RA STi Version 2
      GC8C4DD
      C
      XNC
      EJ20G DW5HJ
      EJ20G DW5HJ
      275
      Manual
      TY752VB4CA
      TY752VB4CA
      First full production STi RA
      WRX type RA STi Version 2 V-Limited
      GC8C4DD
      66C
      EJ20G DW5PR
      275
      Manual
      TY752VB4CA
      Special edition
      WRX STi Version 2
      GF8C58D
      61C
      EJ20G DW4NE
      260
      Manual
      TY752VB3FA
      GF8C58D
      62C
      EJ20G DW4NE
      260
      Manual
      TY752VB3FA
      Special edition
      WRX EX
      GF8C5CD
      PJC
      MJC
      QJC
      LJC
      EJ20G DW5NE
      EJ20G DW5NE
      EJ20G DW5NE
      EJ20G DW5NE
      Manual
      TY752VB4AA
      TY752VB4AA
      TY752VB4AA
      TY752VB4AA
      WRX EX
      GF8C58P
      PJC
      MJC
      QJC
      LJC
      EJ20G DX5NE
      EJ20G DX5NE
      EJ20G DX5NE
      EJ20G DX5NE
      220
      Auto
      TZ102TB3BA
      TZ102TB3BA
      TZ102TB3BA
      TZ102TB3BA
      First production automatic transmission
      09/96 - 08/97
      WRX type R STi Version
      GC8D2DD
      81
      83
      91
      93
      EJ20K DW6PR
      280
      Manual
      TY752VB5CA
      TY752VB5CA
      TY752VB5CA
      TY752VB5CA
      First 2 door coupe
      WRX
      GC8D48D
      EJ
      EG
      EC
      EJ20K DW6HE
      EJ20K DW6HE
      EJ20K DW6HE
      280
      Manual
      TY752VBCAA
      TY752VBCAA
      TY752VBCAA
      WRX type RA
      GC8D47D
      WX
      WE
      EJ20K DW6HD
      EJ20K DW6HD
      EJ20K DW6HD
      280
      Manual
      TY752VB5BA
      TY752VB5BA
      TY752VB5BA
      WRX STi Version 3
      GC8D4ED
      EJ
      EG
      EJ20K DW6PR
      EJ20K DW6PR
      280
      Manual
      TY752VBCAA
      TY752VBCAA
      WRX STi Version 3 V-Limited
      GC8D4ED
      61
      62
      EJ20K DW6PR
      EJ20K DW6PR
      280
      Manual
      TY752VBCAA
      TY752VBCAA
      Special edition
      WRX type RA STi Version 3
      GC8D4DD
      XE
      WN
      XN
      EJ20K DW6PJ
      EJ20K DW6PJ
      EJ20K DW6PJ
      EJ20K DW6PJ
      280
      Manual
      TY752VB5CA
      TY752VB5CA
      TY752VB5CA
      TY752VB5CA
      WRX
      GF8D58D
      MJ
      MF
      MG
      MC
      EJ20G DW6NE
      EJ20G DW6NE
      EJ20G DW6NE
      EJ20G DW6NE
      240
      Manual
      TY752VBCBA
      TY752VBCBA
      TY752VBCBA
      TY752VBCBA
      WRX
      GF8D58P
      MJ
      MF
      MG
      MC
      EJ20G DX6NE
      EJ20G DX6NE
      EJ20G DX6NE
      EJ20G DX6NE
      240
      Auto
      TZ102YB5BA
      TZ102YB5BA
      TZ102YB5BA
      TZ102YB5BA
      WRX STi Version 3
      GF8D5ED
      MJ
      MG
      EJ20K DW6PR
      EJ20K DW6PR
      280
      Manual
      TY752VBCAA
      TY752VBCAA
      GF8D5ED
      71
      72
      EJ20K DW6PR
      EJ20K DW6PR
      280
      Manual
      TY752VBCAA
      TY752VBCAA
      Special edition
      09/97
      WRX type R V-Limited
      GC8E27D
      280
      Manual
      Special edition 2 door RA
      WRX type R STi Version 4
      GC8E2DD
      BG
      BL
      EJ20K DW7PR
      EJ20K DW7PR
      280
      Manual
      TY752VB5CA
      TY752VB5CA
      WRX type R STi Version 4 V-Limited
      GC8E2DD
      280
      Manual
      Special edition
      WRX
      GC8E48D
      EG
      EC
      EL
      ED
      EJ20K DW6HE
      EJ20K DW6HE
      EJ20K DW6HE
      EJ20K DW6HE
      280
      Manual
      TY752VBCAA
      TY752VBCAA
      TY752VBCAA
      TY752VBCAA
      WRX type RA
      GC8E47D
      XE
      DL
      EJ20K DW6HD
      EJ20K DW6HD
      280
      Manual
      TY752VB5BA
      TY752VB5BA
      WRX STi Version 4
      GC8E4ED
      EG
      EL
      EJ20K DW7PR
      EJ20K DW7PR
      280
      Manual
      TY752VBCAA
      TY752VBCAA
      WRX type RA STi Version 4
      GC8E4DD
      XE
      XM
      XN
      WN
      EJ20K DW7PJ
      EJ20K DW7PJ
      EJ20K DW7PJ
      EJ20K DW7PJ
      280
      Manual
      TY752VB5CA
      TY752VB5CA
      TY752VB5CA
      TY752VB5CA
      WRX type RA STi Version 4 V-Limited
      GC8E4DD
      280
      Manual
      Special edition
      WRX
      GF8E58D
      MG
      MC
      ML
      MD
      EJ20G DW6NE
      EJ20G DW6NE
      EJ20G DW6NE
      EJ20G DW6NE
      250
      Manual
      TY752VBCBA
      TY752VBCBA
      TY752VBCBA
      TY752VBCBA
      WRX
      GF8E58P
      MG
      MC
      ML
      MD
      EJ20K DX6NE
      EJ20K DX6NE
      EJ20K DX6NE
      EJ20K DX6NE
      Auto
      TV1A2YB6AA
      TV1A2YB6AA
      TV1A2YB6AA
      TV1A2YB6AA
      WRX STi Version 4
      GF8E5ED
      MG
      ML
      EJ20K DW7PR
      EJ20K DW7PR
      280
      Manual
      TY752VBCAA
      TY752VBCAA
      03/98 - 08/98
      22B STi Version
      GC8E2SD
      280
      Manual
      Wide bodied 2.2 litre special edition
      09/98-08/99
      WRX type R STi Version 5
      GC8F2DD
      BG
      BL
      EJ207 DW1PR
      EJ207 DW1PR
      280
      Manual
      TY754VB1CA
      TY754VB1CA
      WRX type R STi Version 5 Limited
      GC8F2DD
      280
      Manual
      Special edition
      WRX type R Limited
      GC8F27D
      280
      Manual
      Special edition
      WRX
      GC8F48D
      EG
      EC
      EL
      ED
      EJ207 DW1KE
      EJ207 DW1KE
      EJ207 DW1KE
      EJ207 DW1KE
      280
      Manual
      TY754VBAA
      TY754VBAA
      TY754VBAA
      TY754VBAA
      WRX type RA
      GC8F47D
      XE
      DL
      EJ207 DW1KE
      EJ207 DW1KE
      280
      Manual
      TY754VB1BA
      TY754VB1BA
      WRX STi Version 5
      GC8F4ED
      EG
      EL
      EJ207 DW1PR
      EJ207 DW1PR
      280
      Manual
      TY754VBAAA
      TY754VBAAA
      WRX type RA STi Version 5
      GC8F4DD
      XN
      WN
      EJ207 DW1PJ
      EJ207 DW1PJ
      280
      Manual
      TY754VB1CA
      TY754VB1CA
      WRX type RA STi Version 5 Limited
      GC8F4DD
      280
      Manual
      Special edition
      WRX
      GC8F58D
      MG
      MC
      ML
      MD
      EJ205 DW1KE
      EJ205 DW1KE
      EJ205 DW1KE
      EJ205 DW1KE
      250
      Manual
      TY754VB1AA
      TY754VB1AA
      TY754VB1AA
      TY754VB1AA
      WRX
      GF8F58P
      MG
      MC
      ML
      MD
      EJ205 DX1KE
      EJ205 DX1KE
      EJ205 DX1KE
      EJ205 DX1KE
      Auto
      TV1A2YB7AA
      TV1A2YB7AA
      TV1A2YB7AA
      TV1A2YB7AA
      WRX STi Version 5
      GC8F5ED
      MG
      ML
      EJ207 DW1PR
      EJ207 DW1PR
      280
      Manual
      TY754VBAAA
      TY754VBAAA
      09/99-08/00
      WRX R STi Version 6
      GC8G2DD
      300
      Manual
      WRX R STi Version 6 Limited
      GC8G2DD
      300
      Manual
      Special edition
      WRX RA V-Limited
      GC8G27D
      300
      Manual
      Special edition
      WRX
      GC8G48D
      280
      Manual
      WRX RA
      GC8G47D
      280
      Manual
      WRX STi Version 6
      GC8G4ED
      300
      Manual
      WRX RA STi Version 6
      GC8G4DD
      300
      Manual
      WRX RA STi Version 6 Limited
      GC8G4DD
      300
      Manual
      Special edition
      WRX
      GF8G58D
      240
      Manual
      WRX STi Version 6
      GF8G5ED
      300
      Manual
      WRX AT
      GF8G58P
      240
      Auto
      Source Credit -
      http://www.catherineandken.co.uk/sti/wrx.html
