Current Donation Goals
Sign in to follow this
Followers
1 post in this topic
Followers
Similar Content
By fuseseven
Ihave a 94 wrx wagon chassie says it a wrx-sa (sti) 250 hp manual. it has tommy karin rear bumper and tommy karin wheel centers (not fitted at the moment) rear spoiler has triangle bits on the end that no other wagon has,there is a original subaru techincal international sticker on rear hatch thats the only revferance to sti on the vehicle does anyone know anythig about this vehicle like what does the sa mean
By Durty-Sanchez
Right.. the AFM fixup guide! This is probably most relevant to early-mid 90's AFM's that have no servicible parts in them. The basic idea is that over time the solder joints on the connectors become dry and crack, which makes for a bad electrical connection and sometimes an error code. Even if no code is given, you may experience random loss of power from time to time, which can also be caused by this. Sorry about the blurry photos, it was a crap camera!
Anyway, moving on, you'll need:
Solder
Solder wick/sucker (optional)
Soldering Iron (preferably a hot one)
Knife
Silicon or some other kind of sealant.
1. Locate your AFM on the drivers side of the engine bay. It's attached to the airbox by bolts, and to the flexi-joint pipe by hose clamps. It's probably wise to unbolt the AFM completely from everything, although not necessary. You'll need to unplug it too!
2. After getting the AFM off you'll need to cut through the black sealant that lines the outside of the circuitry housing. The lid is quite deep so be careful when prying it out, I managed to crack the outer casing from prying too hard.
3. After you get the lid off you'll see a copper EM sheilding plate that is soldered down by one side. If the plate is loose then awesome, take it out, otherwise you'll need to remove the solder to get the sheilding plate out. Solderwick is great for this kinda stuff, but i'm sure there's more than one way to skin a cat.
4. Once that's out of the way you can see some of the circuitry involved in the mysterious AFM. Down one side you will see 4-5 connector pins that go from the main plug on the outer casing through to the circuit board (see number 3 on this incredibly blurry excuse for a photo). Usually these are the culprits! It's always best to remove the old solder before re-soldering, but you can probably get away with not doing that.
If you look down at the pins inside the casing you'll see that they are actually made up of 2 pins connected with a solder joint (one from the circuit board, the other from the plug). Heat the joint so the solder is liquid then remove the old solder, then add some more solder as necessary. If you don't have solder removing stuff then i'm sure that re-wetting the joint should be ok. Repeat for all of the pins.
5. You're done! Put the EM sheilding back on and re-solder it to the grounding connection. Then replace the plastic lid and seal it with sealant to keep moisture out. This should conclude your adventures in to the AFM, and should be enough to have repaired it. I've done several of these and never had any more problems with them afterwards. If you're problem persists then you may need to either buy a new AFM or find one on trademe.
Best of luck!
Recent Status Updates
Hi all. So I've just seen on Facebook about a thing called The Gumboot rally it's on the weekend of the 7th of April. Goes from Hamilton somewhere down to New Plymouth then across to Taupo and also includes The Forgotten Highway which is an awesome road to drive, as I have done it a few times now. If you are interested go have a look on Facebook should be a fun weekend I reckon.· 1 reply
Stay safe on the roads over this time there are some CRAZY people out there who only think about themselves!!
Help me please Hi iv fitted a dump valve to my vectra c 19 cdti 150 bhp. The 1 I bought was a twinport or receculation valve I don't no just bought and had a go of fitting it my self. On looking at the car I thought I needed to block the 2nd port so have done bought a t and fitted it on the main intake Of The top Of The intercooler to the inlet on to Of The head. Ran the bleed pipe and td it in to the on top Of The intake now it's just realeasing through the revs rather than when I lift of it's not because I blocked the other port is it thanks· 0 replies
Recently Browsing 0 members
Forum Statistics
37,792
Total Topics535,001
