1randomkiwi
LED Fog Light Options
18 posts in this topic
Anyone run LEDs for their fog lights?
As some of you know, I have like my LEDs :P
Unfortunately, my usually supplier doesn't have any power H3 LED options.
If anyone could recommend any, I'm all ears/eyes.
Otherwise I'll look at some WhiteVision Philips or something.
1 person likes this
Share this post
Link to post
I've got some led fogs sitting on my desk. Haven't got around to installing them yet. Currently have some Phillips bulbs which are ok but not blue enough
Share this post
Link to post
Love how blue yours look Randomkiwi!!! Need to do the same to mine!!! Have you tried Superbrightleds.com?
Share this post
Link to post
Cheers man. I'm really happy with these LEDs. Makes the car look way more modern.
I'll take a look :D Cheers
2 people like this
Share this post
Link to post
Loving mine. Don't pass WOF though as the beam pattern is pretty much non existant.
8EF697CB-EB53-4170-B1CE-C48B68EA385E_zps
Share this post
Link to post
Looks mint.
Does the facelift use the H3 or the H3B bulbs?
Share this post
Link to post
The beam spread is annoying.
I had a look at forward firing LED units (like below) but a lot wont fit through the small hole in the fog light housing on the pfl BL/BP and BE/BH Legacys.
$_35.JPG?set_id=2
Share this post
Link to post
Basically, a LED bulb cannot utilize halogen reflector, so if you're gonna swap be ready to lose the majority of practical output from the fogs. Depending on what colour temperature (4300k vs 6000k etc) you get, it'll match the headlights and/or parkers. But yeah, you lose "fog lights" really.
1 person likes this
Share this post
Link to post
Thanks for the detailed explanation :)
I'll probably start looking at some 4300-5000k halogens then.
Share this post
Link to post
I've been looking for something decent too. Ended up getting a BL/BP rev D-E  HID conversion kit from K2Gear, 6000K lamps will be a perfect match for 6000k HID headlights. Will see how that goes.
Share this post
Link to post
At the risk of copping a whole lot of hate, I changed my HIDs to 8000k because blue headlights lol :D
Share this post
Link to post
Got the K2Gear HID conversion installed (easy plug and play). Freaking love it, the spots are the same colour temperature as the headlights, good usable brightness too.
Share this post
Link to post
Is that legal?
Last I heard HID conversions in non-HID housings were a big no no?
Share this post
Link to post
1 hour ago, 1randomkiwi said:
Is that legal?
Most likely not, are LEDs in spots legal?
Share this post
Link to post
Sorta not. Don't pass WOF's for the non existant beam pattern with the standard housings. They are legal though if you fiddle with the wiring and run them as DRL's
Share this post
Link to post
Yeah as @Andy_Mac said. LEDs don't have a great beam pattern so don't work well in some lenses.
Was just curious as to if the law had changed regarding HID conversions cause its been ages since I looked into it and think it would look mint for fogs.
I'll probably just stick to my GT3 yellow bulbs :P
Share this post
Link to post
  • Similar Content
    • By Leigh29
      Hello
      I own a Subaru Legacy B4 1999 automatic, today I took it to get a service and Wof. I was only aware that the car may fail the Wof as the rego lights were not working, 3hours later after waiting I was informed by the company that they had replaced both rego bulbs and had tested the fuses and they still did not work so i would need to go to an auto electrician as the mechanic believed it could be a wiring issue.Therefore the car failed the warrent. 10minutes later I paid up and jumped in my car, before I drive out onto the road I applied my brakes and heard the reversing sound, I checked to make sure I was in drive which I was yet I could still hear the beeping noise as if the car was in reverse.
      I drove back up to the company that had just serviced and completed a Wof check to ask if they had crossed wires or done something.
      Two mechanic's came out and I advised them that every time I apply my brakes I was hearing the reversing sound even when the car was in drive. One of the mechanics said it was serious electrical fault. I asked if this was related to the two back rego lights not working and he said it could be. I also advised that my car had never done that, the mechanic said ever when they tested it, it was not making the sound. So now I have two issues that need to be assessed by an auto electrician.
      It makes me wonder if the mechanic had caused the second issue of the "reversing beeping sound" when the brakes are applied or if it is just another problem to sort.
      The car went into the shop with 1 issue and came out with 2.
      Any feedback would be great.
      Thanks
