Digital dash software
Jamieedwardcook
Hey guys after some advice. After many years of playing with cars and spending countless ammounts of money on go fast parts and gauges im toying with the idea of running a digital dash software in my gen 5gt wagon but unsure what is the best one. Is anyone running one and if so which one would be even better if someone in southland has one that I can we going!
Torque is pretty average. BTSSM with a tablet is near perfect. Even better on the later cars as they removed k-line and went for CAN completely so polling is crazy fast. Can get 20-30 samples per second with mine so with a limited parameter set it'll be more than accurate enough.
Haven't got any pics of how the screens currently setup but its essentially limited by what you actually want to see.
Not sure on whether there's a nav panel that'll fit a tablet the way the 4th gens did though.
36980C57-FB8C-4E69-96D8-6B843266ABE3_zps
Does this kind of thing work with link?
  • Subscribed Member
Newer Links do have CAN bus and OBD2 on them,so you can wire in an OBD2 plug and a BT or WIFI OBD2 reader that you can then link up to them.
I know my G4+ plugin can do this, so pretty keen to use it.
That's the Torque Pro that is, unsure about BTSSM.
Andy whsts the cost for the software you use looks pretty good
13 minutes ago, gotasuby said:
Get windows tablet with USB. Setup a new page In the software with new gauges set to what you want, set up the ranges. Set it to start in full screen and start software with windows start and set to automatic connection.
Ah right i see. Cheers
