Recommended performance tuner
RaKid
Hi team,
Well, I finally picked myself up a super tidy V3 STi after driving a people mover for the best part of four years.
It has an exhaust and intake but other than that she's fairly stock, and straight.
I'm after recommendations from you guys and girls regarding (the next) performance upgrades I should be looking into and recommendations on who should do the work.
One name I have seen around here a little bit is Possum Bourne Motorsport.
I would be keen to hear of your experiences, good and bad, at tuning shops around Auckland and your best 'bang for buck' performance upgrades that you would recommend for my stock-ish WRX STi.
Thanks in advance.
Brett
No personal experience with Possum Bourne Motorsport but see good things on FB, When it comes to getting a tune D-Tech in Tauranga are ace.
If its stock you will be rocking a VF23 iirc which is capable of creating good usable street power. just add breathing mods, it wants to get air easy and get it out easy.
Lads on here who are more familiar with the era you have will chime in about what the ECU limits are etc
You guys are legit - thank you so much for the comments. It sounds like I need to give D-Tech a call.
5 hours ago, Dairusire said:
Also will recommend D-Tech. Tunes are SIGNIFICANTLY cheaper than PBMS when you're talking something like a Flex Fuel tune.. about $700 difference..
I gather there are different types of tunes for different purposes, would that be correct? What is a Flex Fuel tune?
21 hours ago, newsuba said:
all the above plus;
dampers will be getting tired on a v3 too
What do dampers do sorry? (I'm no mechanic but like to understand these things)
22 hours ago, kwi_fozze said:
Tyres, brake pads and fluid
Swaybars, endlinks, anti lift kit and alignment
Then start looking at increasing power
I  have RE001s on the rear and some Kookmins on the front. The Kookmins don't make me feel very comfortable, as in, I would feel way more confident with the RE001s, but I
have minimal experience with performance tyres.
19 hours ago, 1randomkiwi said:
This guy... #shamelessplug
No shame at all hey haha
23 hours ago, evowrx said:
Fuel pump, g4+ plugin/iat/boost solenoid, dtech tune. Drive it and be a happy lad. For the ultimate enjoyment add tyres, brake pads and rear swaybar along with a birthday fluid service. Timing also if its due.
Stock fuel pumps no good?
Does the IAT go on the manifold or where? Does I need to fabricate something to fit?
Will the rear sway bar keep the nose straight will it?
That you're right about. Flex Fuel tunes are used in conjunction with a flex fuel sensor, which senses ethanol content. This is incase you're wanting to run Normal say 98 fuel and also run E85 etc so you don't need to worry about possibly popping a motor due to too much or too little of X fuel type in your tank to be on say your 98 tune or e85 tune. :)
Chances are the pumps old as f*ck and they dont handle the extra pressure well. Best bet is to upgrade just call it preventative maintenance.
The IAT goes within 6" of the throttle body on the turbo side. If youre running tmic just tap a hole for it in the tb end tank so its post core.
Yep stops the horrible understeer effect subaru are so famous for.
18 minutes ago, Niran said:
We should ask D-tech to do a clubsub discount. With all the recommendations we've been sending their way  :D
I dont think they need the business tbh. Busy enough as is and our type are the C***iest customers.
Great articles man - cheers for sharing. I definitely have a better idea of what I want to do. Think I need to really get familiar with the motor too.
So I just took her for a 'real' drive yesterday - tried to keep up with a 1 litre bike through the back of Waimauku all the way to Hellensville. It was one hell of a drive. But I noticed myself forever trying to keep the car in the corner. As in, the power was fine, I'm happy with it, but what's power when you can't even corner properly. She was all over the place and I felt the rear slide out once or twice (is that over or under steer?).
Also, the body was bottoming out on the tyres but I did see an invoice for guard rolling in the glove box. There must be any number of reasons that the body was hitting the tyres I'm assuming?
Brakes started to get hot after this back street race so had to chill on the drive home. But wow - what a car.
On 10/20/2016 at 5:54 PM, newsuba said:
Rakid;
Dampers = shock absorbers
https://en.wikipedia.org/wiki/Shock_absorber
Thank you! I have read. As I was mentioning above, handling was challenge - I wander if old shock were contributing to the poor handling or the bottoming out on the tyres?
On 10/19/2016 at 6:54 PM, kwi_fozze said:
Funny you should mention that, I have a set of KYB excel-g's on v7 sti springs with a spare set of gc/gf rear tophats sitting at mine i'd be willing to let go of...
Would this be considered an upgrade to my, presumably stock, dampers?
How many beers are we talking?
Not a drinker, but i'll let em go for 250 ;-)
Also have a factory rear swaybar for a v7 sti if you want it, with end links. Dont know if it'll fit a bc but its there if you want it.
Took mine for a good thrashing today, and the uprated rear bar with the factory front bar is an odd feeling. Like, you can feel the front roll around but the rear sits solidly on the road.
Sounds like you know where the shortcomings are, i'd be getting some new struts, full fluids change with new pads and rotors, do your clutch fluid too.  Get some new sticky tyres on to it (re003 or similar)Start hunting around for suspension goodies, rear swaybar, front swaybar, endlinks, anti lift caster correction bushes and a good alignment.
This guy has some nice bits and pieces
https://www.facebook.com/groups/140180922814491/permalink/697851183714126/?sale_post_id=697851183714126
Excuse my ignorance but, I presume that those dampers would be an upgrade?
Is the v7 factory rear sway bar thicker than what I have? I haven't actually put calipers on it to measure. I did see a Whiteline 22mm for sale on Trademe so it's good to hear that when you fitted yours it was in fact a more solid rear. Would hate to 'upgrade' it only for it to feel the same.
I did some inspecting over the weekend and all the fluids look brand new and in really good condition to be honest. The brake pads have heaps of meat on them but I couldn't see what brand they were. It would be nice to get slotted rotors all round - that would really give me some more bite and hopefully keep them slightly cooler under load.
When fitting a new sway bar is it recommended to upgrade the end links too? Is it a necessity or a recommendation and what benefit do I get from this?
I'm really interested in an anti-lift kit. I suppose to some degree it's preventative maintenance too?
I've also looked into a rear strut brace but I'm not to certain of the actual benefit of this? Would I need an adjustable one, if there even is such a thing, so that I can increase/decrease torsion?
Thanks for the link - will look when the boss is out of the office :)
Anti lift kit is the 2nd most noticable mod i've done, totally changes the front end geometry.
The struts, not an upgrade per-se, more along the lines of "best replacement strut available in nz at a reasonable price, that isnt platform adjustible."
They are ok, little bit more of a touring strut, they arent valved as agressively as the v7 sti inverted struts so not as harsh.
Endlinks, your call. Did em on my car because of the age of them (nearly 300k on factory links) so couldnt say for sure.
Rear strut brace. Worth if its a wagon, much of a muchness if sedan as they are pretty stiff anyways.
What was the most noticeable mod? I figured the anti-lift kit would make a huge difference, along with an upgraded rear sway bar.
Would I need a front sway bar upgrade with the anti-lift kit though?
I don't think the anti-lift kit is something I could tackle myself. Who did yours?
v7 inverted struts sound fancy - I don't know what the inverted term means so I'll research it.
My thoughts too on the rear strut brace.
Oh and I had a look at that facebook link you sent through - those are some really nice bits but what the hell is a k-brace?
I'm full of questions :)
  • Similar Content
