A_Fat_Duck
Intake Temp
15 posts in this topic
Hi guys, been looking through my ECU logs after having both the MAF and IAC die on me a while ago and trying to troubleshoot. I've noticed that the intake air temp is almost always at -40degC but can go occasionally up to -36degC. Anyone else had a problem like this and what could I try to do to fix it?
Share this post
Link to post
Cant help but all the logging ive done with fmic and big turbos has me at ambient thro to +10deg c max.
Share this post
Link to post
ambient + 10, what intercooler? Mine peaks to around + 40
On topic, where are the intake temp sensors?
I would replace it based on the data it's giving.
Share this post
Link to post
Chinese specials. 4" pre tb.
Share this post
Link to post
This is reading negative 40 not plus 40 with a stock turbo and not sure what fmic but it's a decent size. Where is the intake temp sensor on a 99 GC8?
Also not sure if I said but it's reading -40deg c right from the start even with the car sitting around not running
Share this post
Link to post
Yep got the negatve somethings clearly F***ed. If its a gc8 it should be in the intake pipe post airbox. Might not be plugged in.
Share this post
Link to post
thought as much.. although the previous owner put a pod filter on so I have no idea what they've done. everything that I can see looks to be plugged in. What does it look like?
Share this post
Link to post
Ovalish black 2 pin plug pretty much under where the airbox sits. Is part of the loom that comes from around the brake booster area.
Share this post
Link to post
Just had a look and I cant see anything like that at all, does anyone have a picture of what it should look like and location?
Share this post
Link to post
5 hours ago, pedro said:
Google it..
I tried that and saw quite a few different ones and it definitely didn't have the actual location of it o.O
1 hour ago, evowrx said:
Thanks @evowrx I'll have a look when I'm done with work
Share this post
Link to post
4 hours ago, evowrx said:
I've got a v5/6 but I assume it's in the same pipe as the 3/4 that you've linked? There's a part of the loom right under that by one of the injectors that looks like it's been messed with and electrical taped again so when I have time I'll try pull it apart and have a proper look as I assume it would have come off of that as it looks like it traces back to the brake booster.
Sorry for sounding like a muppet, I've only ever worked on diesels before this O.o
Share this post
Link to post
    • Steve
      Just wondering if anyone has got any kind of gps tracker on there car? Are they worth while? Any particular sort I should get If I got one?
      · 4 replies
    • H6boxer
      Hiya, would anyone in/near Wellington have a spare passenger floor mat for a 2006 Legacy b4? I’ve looked at a few aftermarket options but I’d like to find an original. Cheers!
    • Steve
      I'm looking for some mud flaps for my car, was just wondering where everyone gets there's from?
      · 4 replies
    • WAxOFF
      -SUBMERGE- Wellington
    • madmike
      wassup...
