B4 I was 250T
Primary wastegate porting
You could try here:
Turbo Care NZ
Phone number: 03 366 9360
After Hours: 021 393 493
Email: info@turbocare.co.nz
Fax number: 03 366 9370
They are based in Papanui, but don't know anything about them, came across them while looking for something else turbo related.
Share this post
Link to post
I'm sure this has crossed your mind, but just in case all you need is a little encouragement....... DIY
If its just the wastegate that needs porting and you're not trying to port and polish the scroll of the turbo then absolutely DIY
Share this post
Link to post
Don't the primary turbos on these die if going to a bigger downpipe/de-cat? Wouldn't porting have a similar effect?
Or was that earlier models?
Share this post
Link to post
Would have thought it'd have the opposite effect. Negating the potential overboost caused by decats/free flowing exhausts as the port would then 'technically' flow more at a given duty cycle
Share this post
Link to post
2 minutes ago, A_J_T said:
Yea, primary has the gate secondary does not.
Right. I was thinking the other way around. Cheers
Share this post
Link to post
Oh it crossed my mind but I also don't trust myself and can't afford to screw it up! But thanks for the vote of confidence ;)
Share this post
Link to post
I believe someone here (and I don't remember who but I think it may have been Rosssub or Lachlan) did it. Apparently the flapper is bigger and a little bit of material can be removed. Wish I could remember who did it?? :|
5 minutes ago, Jono24 said:
Look out for a spare from pick a part, doesn't matter if it has a stuffed bearing, just crack into the exhaust housing!
Don't remember when I last went to pick a part but overtime I've been they've never once had a tt BE/BH :(
Share this post
Link to post
Yeah Rosssub did...
Share this post
Link to post
 Hornby has at least one TT currently, intake and exhaust headers have been removed so the turbos are just sitting there
Share this post
Link to post
imo removing the V-Band holding the housing to the CHRA would make the job alot easier and eliminate the risk of metal filings getting places they shouldn't be.
The most difficult part of this entire processes is actually removing the turbo from the car :rolleyes:
Share this post
Link to post
10 hours ago, ADIKT said:
Is it worth it? Is it really going to make much of a difference?
I don't know if it is but at the same time why not? I have a spare primary that's off the car at the mo and because I refuse to ever go S/T I might as well do everything else I can. If it makes a difference, great, if not then I haven't really lost anything :)
Share this post
Link to post
From memory when my primary was off the car, which may be the spare you have anyway (?? my memory is shite tho!!) or was that the secondary? anyway I think the wastegate flapper opens past 90 deg when its disconnected, so it may be able to be bored in a mill, which any engineering shop with a mill ought to be able to do.
The one on the Track Hacks TD-05 does anyway.
PS: you need to update your banner!!
Share this post
Link to post
Join the conversation
Reply to this topic...
  Only 75 emoji are allowed.
