Racing fluids quiz
16 minutes ago, GC8E2DD said:
Motul PA90 and Gear 300, the TRD version of RBF600 (because it's cheaper). Engine oil is all over the shop; usually in the 10w40 range. But this topic has been done to death hasn't it?
After track/race orientated feedback not average daily driver. Not trying to find the best oil just distinguish what people are using on track.
Engine: Motul 300v 15w50
Gearbox & Rear Diff: Motul FF LSD Type 2 75w90
Brakes: Castrol SRF
Why: I was recommended 300v for the engine many years ago by an original member of Clubsub - have always stuck with it since then. Plus my boss swears by it, and with his involvement with engine building/tuning in various forms of motorsport over the years (and dealing with Subarus) this further backs up my original recommendation.
Used Motul gear oils since I was using the engine oil already and it is apparently kinder on the synchros than the Redline LW shockproof I was using previously.
Castrol for the brake fluid as I haven't had much success with the Motul RBF fluid :-/ (I am pretty hard on brakes though).
8 minutes ago, gotasuby said:
We use motul rbf660 for brake fluid. Castrol edge 0w-40 for engine. Lsx90 for diff and syntrax for gearbox. This is with dog box.
Just an fyi, the TRD brake fluid is Motul RBF660 (might be RBF600 as mentioned above. Can't remeber off the top of my head) however it's a shitload cheaper. $25 versus a 35+ I think.
Edited by Dairusire
I'm running motul 4100 15w50 for the engine, its a motorbike oil, cheaper than 5100 but same viscosity and I've never had an issue with it (i think there was something else that made it good for a car too, some additive thats in it???)
brakes i run motul rbf 600 or 660, whatever i can get for a good deal at the time
trans is motul gear ff lsd type 2
Rear diff is motul pa90
I get a relatively good deal on motul and my engine builder swore by it, Never really ran anything else in my track car as I've never had an issue
  • 3 months later...
Motorcycle oils have no friction modifiers in them as they run wet clutches bathed in engine oil and the modifiers will ruin them. You're far better off running a proper automotive oil.
