Brembros on BL/BP
ADIKT
15 minutes ago, sobanoodle said:
Fronts: bolt-on
Rears: adapters and need to address 170mm to 190mm step up in hand brake size. Thicker handrake shoes/inserts/DBA rotors.
I had inserts, afaik @Invisible runs DBA rotors specifically designed to address the issue, does not know of anyone running thickened shoes.
Do I need to change the front rotors?
I remember seeing the DBA rotors a while back
35 minutes ago, sobanoodle said:
Fronts: bolt-on
Got a link to the inserts you used?
4 minutes ago, sobanoodle said:
Had THIS SET, inserts and adapters. You won't like the price :D
Imho you can probably machine down a set of old Brembo rotors, reckon that's what they do anyway.
The DBA option will most likely be cheaper lol
I'll keep searching for the part numbers
Thanks for your help bro
11 minutes ago, Invisible said:
Yep I am running the DBA rotors that @sobanoodle linked :)
I think when it comes time to replace them I'm going to go with thicker rear shoes instead
So with the thicker shoes you can just use normal sti brembo rear rotors? Where would I find the shoes?
Thats what a few US guys have done but that price is pretty farkin crazy. Have also heard of people somehow getting extra pad material bonded to the existing shoes, but that seems to have issues with cracking over time.
http://www.knsbrakes.com/c/caliper-item/2287_Subaru+V1+Rear+STI+Brembo+Caliper+Upgrade+w%2F+Oversize+Park+Brake+Shoes/31536_Rear+Adapter+shoes+-+For+Legacy
Can't beat perfectly fitting Legacy 190mm rear drums though can ya ;)
9 hours ago, Invisible said:
That's the plan...
I actually don't know yet...I'll probably get @Subirex Automotive to suss them when I need them, maybe ask him if know's where, cause I'm pretty sure he is running thicker shoes
i got mine from Aussie, i think they were around 200 for the rear bracket and shoes. from memory the shoes were like 14mm thick (i will confirm this when i pull my rear rotors, brakes need done soon). i would probably get the local brake shop to mould a thicker shoes on your current linning.
Damn, is that for one side or both sides?
