BP5 Legacy Kenwood to McIntosh Conversion Possible?
legacyspecb
Hi guys,
I have an 03 Legacy wagon with the base (kenwood) stereo in it. I have an opportunity to buy the McIntosh stereo, amp and speakers with door cards for only $250.
Just wondering if this sort of a conversion is possible or if it isnt worth the hassle?
Thanks,
Sam
1 hour ago, legacyspecb said:
I'm kinda working with a limited budget being a student and all, and fascia kits are not cheap not to mention buying a headunit.
Does the swap require a new loom, or do they have the same harness on the back?
Get a single din conversion kit instead of a cubby pocket, install a mechless 1DIN stereo in there, upgrade speakers and you're done. Later on can add underseat amp/sub.
If I wanted to do a headunit, I wouldnt want to half-ass it and do a single din headunit. The $250 is for the McIntosh unit with heater controls, all the door speakers and sub, and all the door cards too, so in my opinion it is a far better deal.
My only concern is that I've heard that you need to replace the stereo loom/wiring with the one from the McIntosh system, which sounds time consuming. Is it really necessary? I know that the McIntosh systems run more speakers, but is there anything special about the wiring that has to be run?
Definitely sound quality. When I have compared my system to my friend's McIntosh systems, they sound much better, and there is a massive difference at high volumes. Connectivity wise there is a difference. My Kenwood headunit doesnt have an auxilary option. The only way of adding any extra connectivity is by getting a GROM unit that plugs in and overrides  the cd player. On the McIntosh headunits you can add an auxilary or bluetooth much easier.
I've got a GROM in mine and it plugs into the port for the optional CD changer and doesn't override the cd stacker on the unit itself, unless you have a different kenwood to mine possibly
Yeah I think that you must have a different kenwood unit, there are quite a few different different iterations.
I think I will just go and buy the stuff, could onsell it without too much of a loss if it doesnt work out I reckon......
  • Similar Content
