Ignition lights ON, no crank
Les
My sister has got me looking at her 2002 Subaru Impreza Import. Ignition lights come on, but will not crank engine in the start position. Fuel pump doesn't seem to have power (trying to avoid having to replace fuel pump). I've checked a relay OK, but is there another relay or sensor from the fuel pump end to the ignition? and if so where is that located. All the fuse descriptions are of course in Japanese, but I've tested those OK. There  are a bunch of relays in the console but what for - who knows!. Thank - any tips, much appreciated.
when you turn key does it just click instead of cranking? if so - likely a flat battery bro - could be alternator related also but try battery first
if it cranks when turning the key but does not fire then thats a whole other bundle of worms, could be heaps of S***
First up - the foot on the clutch all the way to the floor . . . . bugger me worked perfectly!!. Awesome thanks heaps. (see last para below)
Secondly, I made the mistake of replying to you all individually via emails yesterday. . . . and then found out just now "Mail Delivery Failure". So it probably looks like I never responded to your tips and hints. My bad.
So . . I had already replaced the battery and there was no whine from the fuel pump.
Today with engine cranking :), but not starting (on the key), there is still no power getting to the fuel pump, so no "whine". My next plan is to just follow the wire(s) from  the fuel pump up to a relay to the ignition. Because the fuses/relays are in Japanese can someone tell me on this model where can I locate the fuel pump fuse and/or relay. (even tho I have checked all the fuses). I'm gonna recheck a relay which I thinks is the fuel pump relay, just cos it clicks, doesn't mean it's good.
Note - my sister bought the Subaru at Turners, been stolen and de-registered. "We" had no idea about the foot on the clutch. Thanks again.
