1996 Twin Turbo
TNHSTI
Hey guys just looking at getting a project car found a 1996 legacy gtb bg5 manual and i had a drive everything runs ok apart from it feels low on boost especially on primary turbo, is there anything i should look for first up to make sure its boosting ok?
Okay so got the boost gauge on and since ive got rid of the stale fuel and chucked some 98 in it seems to be a bit better, so on primary its doing about 6psi and secondary it does 10psi
It basically feels sluggish to start spooling up any ideas? Engine bay is factory apart from a bov car has done 220ks and has been regular service
Have you checked for any stored codes? Also check for vac leaks and or pre turbo exhaust leaks, blocked cat converters. Boost solenoid could also need a decent clean out. Should probably be 10-12psi on primary and 12-15psi on secondary.
Sent from my iPad using Tapatalk Pro
Sweet will check those items , where abouts is the boost solenoid?
