Legacy twin scroll vs sti twinscroll
I am planning a twinscroll conversion on my single turbo gtb, I picked up a blown up bp/bl motor for next to nothing.. is it worth getting the sti twinscroll headers with the lager diameter because I am planning an aftermarket turbo like a tdo5-20g or similar  .. or will the smaller diameter legacy headers perform fine?
1 hour ago, broku420gtb said:
For the turbo you mean? Planning on using some sort of Adapter to either a different twinscroll flange or somehow getting the uppipe modified...
Are you planning on big power? If youre going for the twinscroll thing cut straight to a holset.
I'm currently at 200kw I'm wanting to get to around the 240-250 range no higher because I'm running a factory v7 sti bottom
end and I hear rods don't like it over 250kw.. the thing is I want to try stay v7 sti topmount ... already have fuel pump injectors link Etc.. I was thinking some sort of holset or garret
. don't know lol
^ This. Do this.
Forget about Top mounts, they're a waste of time. You get more reliable, consistent cooling from a Front mount.
Also Holsets are awesome with a small ID header. Which I can prove later tonight as @Furze and I are down at D-Tech atm getting a Version 7 STi factory long block with BL/BP headers and a Holset HRC35/2 tuned. We've already passed 250kw at a guess at 21psi. Hoping for 300kw Dyno power run but safe around 280-290 :)
55 minutes ago, evowrx said:
Get a fmic and a HRC35/2. Have a read of my holset how to it may seem a little daunting but not too bad if you know someone whos not a S*** welder.
I do happen to know a welder who's not S*** lol can you link me it can't seem to find it
. don't know lol
I've been running 268wkw on a V7 STI bottom end for a little over 3 years now, it's happy as.
