Dash doing weird Sh!t
Marky
Bought a car knowing it had this issue... now not sure how to fix
Short version - the dash gauges play silly buggers. The fuel gauge will periodically give up, and drop from wherever it is to 0 over about 45 sec, then perk back up. Temp does the same, and the rev counter has just once decided to just read 0 while the motor was running.
Where should I start - is this likely to be a dash cluster issue or earth related? Alternator looks to have been already replaced, and it has one of those stupid Japanese earthing kits from battery neg to anything unboltsble
  • 4 months later...
I have a similar issue. My dash goes black then starts flashing..as well as petrol gauge but never temp gauge. The two lights on the aftermarket gauges also go on and off. Most of this happened after a motor transplant..however i could bang the top of dash and it would go back to normal.
Tonight driving home changed it from tiptronic over to second gear to go up my driveway and it started acting a bit peppy. I notice the dash lights were on but the speedo/rev counter red stick lights were out and the indicator lights were both hard on.when i stopped it started revving high so i turned it off....Help what is wrong!!!
could be all kinds of things but best place to start is the grounds
