clubsubtalk
Nate_ive
first time here so bare with me. 😁
I recently purchased a v3 Impreza.the ej20 was rebuilt with a vf28 when I bought it.the car goes great,and fast.but,I'm looking at getting a t3/60-1..now my question is,would it be wise to get new forged internals for the ej20 or move up to an ej25? if so will a long block fit?or would I have to get a short block.would I have to relocate engine mounts? any advice would be appreciated just looking for realistic answers before I start building.
Long Block vs short block do not refer to the 'size'
Short block is the Block itself including Pistons and without ancillaries like intake or even the Heads I believe
ej20 and 2j25 are the same size, sorry thats about as much help as i can be sorry, not that good under the hood
Your kind of all over the show a bit but here goes...
1. Jokers spot on
2. ej20-25 will all bolt right in to the bay but having the right bolt ons is key. Hence short block (Block without bolt ons) vs. Long block (block with manifolds, Heads etc.)
3. When putting a bigger turbo in consider three things that need to work in unison ECU, Injectors and AFM(If your not deleting it).
Bigger turbo means you will probably need bigger injectors to keep up, bigger injectors mean better (tunable or flashable) ecu to keep up. Remember X PSI on a VF28 is not necessarily equal to X PSI on a different turbo. A smaller turbo will flow less at X PSI a bigger one more at X PSI. The more air a turbo flows the more fuel the engine needs to keep its S*** in order. For example 18 PSI on a v5 with Yellow injectors and a VF22 = Fun times 18 PSI on a GTX3071 and yellow injectors on the same car will have issues pretty darn quick.
As soon as you start getting into the realms of retunable ECUs on earlier models forged internals is recommended IMO.
Bottom line, If its fast as it is and you dont have a big arse stack of cash burning a hole in your pocket just enjoy it and do something when it shits the bed. Not before. In the meantime stick about, ask questions and do some reading :)
  • Like 4
