Cleaning Rims
Im looking to try clean up the inside of my rims from the RS RA and wanted to know the best way to get rid of all the crud and brake dust thats built up over the years on the inside of the rim.
I have tried brake clean and scrubbing and heavy duty degreaser and scrubbing, which removes some but still leaves more than I want.
I was thinking about using a wire wheel on the inside faces to clean the up but unsure if this is wize.
Any help would be good.
Will post a pic up of the condition of them when I get home
I tried to do the same with my v7 wheels. I used dragons breath. The face of the wheel came up mean but the back and inside of the rim almost had no change. I thought there would be paint under there but looks like they didn't paint the inside of the wheel so the finish is rather rough, could just be worn out though
I'm also interested if anyone has a good solution for this. I went through a similar process as both of you trying to clean a set of gold speedlines for my gc8. I have the wheels off the car and have hit them with wheel cleaner and heaps of scrubbing plus tried a whole can of crc degreaser. Degreaser and a stiff bristled brush works really well to remove the tar and old stickies from wheel weights but I for the life of me cannot remove the discolouration from the years of brake dust.
I think a wire wheel would just remove the paint if they are painted but if it is bare alloy it may work. I would assume there is some sort of clear coating on the alloy wheels also so it may not work.
The insides are always a pain to get clean especially if its not painted or anything, the brake dust and crap just sticks and its also hard to access when its on the car. When you get them clean you wanna keep em clean even if u take em off once a month and get right inside.
As far as cleaning it, Im not too sure how to get rid of all the crap on the inside other than wheel cleaners and things. Would also like to see if there is a way to get it off tho.
Edit: If its not painted or anything, whats stopping you sanding it all back and giving it a coat of paint and clear coat.
35 minutes ago, Kiwi_Fozze said:
Motomuck has released a bottlenof dragons breath equivalent, but significantly cheaper. Works really well. Get in to it with a stiff bristled brush, you may have to go over the rims a few times to loosen everything up
Where do you get it from?
13 minutes ago, Leufkax said:
BNT tend to stock Motomuck, and if your local doesn't have it they can definitely get it.
I don't have a "local" only place in town that sells automotive stuff is mitre 10 who obviously don't have much. I'll give bnt a call when I run out of what I have now, thanks.
I will give the washing powder, warm water and scourer tonight when I get home.
Im not to worried about damaging any clear coat on it as I will give a respray once done anyway.
My dad gave me a couple of bottles of heavy duty graffiti cleaner, so I tried a little bit on one of the rims with a steel wire brush, seemed to amke a good difference but not as clean as I was hoping
