99 gtb low beams dead?
iludez
So I've tested with my basic light test on 12v and all the wires are getting power.
If I flick the switch a bunch of times I can sometimes get the left to come on. So pretty sure it's not a bulb?
Sent from my K3 Note using Tapatalk
So probably stuffed ballasts then. Kinda odd that both crapped out at the same time though.
They wired in to the rear lights too? So no rears and low beams.
Any idea on cost to replace ballasts? And anything else I can check first?
Na ballasts are only for the HID bulbs, so the rears are doing the exact same thing as the fronts would rule that out and be a different wiring issue.
Are you getting 12v at the bulb connectors for the rears or somewhere else?
I haven't checked rear yet, just didn't see any lights come on. So I assume front and rear are tied in?
Can tell this is going to be a head scratcher. Will have to take it to an auto sparky I guess
