Thrust bearing replacement
Domsy
Hi guys
I have been told that the whining noise when i reverse and the slight jolting when high rev before changing gears is because i need my thrust bearing replaced. Can anyone confirm this and give me an estimate on how much it will cost. The car is a 98 forester stb.
Thanks Domsy
Not at all. Just whining when in reverse. And no whining at all and gears all change great. Clutch is great. But recently when boosting at each gear change it delays like the the turbo lag. But every gear. And only at high rev before gear change
Ehhh for clarity are we talking about the clutch release bearing (aka throwout bearing, occasionally called clutch thrust bearing) or the crank's thrust bearing?
One is a bit of a S*** job, gearbox off, may as well do the whole clutch and skim the flywheel while you're in there, also rear main seal and kidney plate.
The other thrust bearing, and the one more conventionally referred to as such, is the one that stops your crankshaft going for a journey, and is an engine-out disassemble-the-motor job to change AFAIK.
17 hours ago, calebwrx said:
Reverse gear is straight cut so it will whine unlike the others that are helical, I guess you're saying your reverse whines more/sounds different to other cars? A video will help a lot here.
Have you removed and inspected the wife from the rear seating? Sometimes you get a "chat" sound when reversing.
