Bg5 tt issues
Ross
I drive a legacy bg5 and i need some help identifying what issues my car has. Issue 1 is that on a cold start I have noticed I get alot of what is possibly steam out of my exhaust? No noticeable smell like burnt oil or coolant just happens every morning in what I think is an excessive amount. I have a catless primary down pipe also a small but consistent loss of coolant, haven't been able to locate the leak and am unsure whether these could be related.
Another issue I've been having is this persistent smell of oil or over fueling when on primary boost, have a replacement turbo to drop just haven't had the time to install yet, I suspect it's the primary leaking oil because I have oil within the tmic but could it also be a leaking injector causing the smell? Or the white smoke on cold start due to running rich? Just done a 5000kms service and my oil was pretty darn black,  Anyone know where I can get them serviced? Any input is appreciated, cheers
Your first issue is too many turbos. If it's just steam, as in water vapour, don't worry. Sign of a healthy engine. Burning coolant stinks, and really stings the eyes, so you'd know if it was that. Oil smoke is blueish, so again, you'd know. Maybe time for a pressure test to pinpoint that coolant leak? If the pressure drops, clamp the lines on both sides of the turbo. If the pressure drop stops, you've found your leak.
