subframe lock bolt kit help!
Subru
Im in process of installing subframe lock bolts but they dont wanna go in. I can screw it in most of the way (after aligning) but when its tight af there is still 1 cm of bolt shaft showing.
(lol ignore the youthanisms plz)
Just to make sure im doing it right here is what I did:
Drove rear wheels up ramps
loostened 4 subframe bolts
moved subframe around
attempted to put subframe bolt in
opens clubsub
8 hours ago, Kiwi_Fozze said:
A few choice swear words definitely helps!
Certainly did... I thought it was tight but when I used torque wrench with proper torque specs, it kept going in until it was seated properly. Also did steering rack bushings (well one of them, drivers side one seems impossible... :()
Driver's side, loosen off the steering u joint
