Could someone explain this? WRX STi
koochkooch
Looking to buy this car - its a 2006 STi. I haven't seen the car in person, but this is an image showing the dashboard with various lights apparently flashing (please see image):
https://ibb.co/eXKfHb
Wondering why the following are are lighting up:
-Engine light
-Oil light
-"R. Diff Temp."
-DCCD
The only description I've had so far is "There is a engine check light due to exhaust modifications." Not sure what kind of exhaust system it is.
Thanks
When the key is in the "on" position but the engine has not been started all of the lights are illuminated to test their function. That is the case in the picture you linked. When the engine is running the lights 'should' go out.
I highly recommend if you are wanting to buy this modified car and you know very little about it, that you get a pre-purchase inspection done by a mechanic familiar with modified Subarus. If you don't know what you are buying it could cost you a lot more money in the future.
  • Like 4
Would be vary cautious man, I purchased my WRX that had "easy fix issues" and turned out I had to spend another 4k on it.
Get someone to check it out for you as there could be underlying issues. guess its pretty easy to blame a few mods to cover up the reason the lights are on.
  • Similar Content
