loss of boost wellington
More than likely a torn or loose connection somewhere between the turbo outlet and throttlebody.
Will feel like a fast NA if the leaks only showing once building some pressure so still might see atmosphere or slightly higher pressure rather than negative like a NA.
Options are to pull everything apart and check for leaks piece by piece or jimmy up a way to pressurise the intake after the MAF and chuck a few PSI through it and you’ll hear it hiss 90% of the time where the leak is
  • Similar Content
