Sign in to follow this
Followers 0
DuCKy!
EJ20Y Valve Clearances
10 posts in this topic
Hi guys, just doing my valve clearances on my BP5 Legacy GT (facelift).
I've read that the valve clearances are:
Intake - 0.20mm / 0.008"
Exhaust - 0.25mm / 0.010"
However, what are the tolerances?
At the moment I've got 4 of my intake ones at 0.007", the other 4 are at 0.008".
5 of my exhaust are at 0.011", the other 3 are way out (0.014" and 0.013").
This is after a rebuild btw, and that's the best I can do with my existing stock shimless buckets. Just wanted to see how many I need to order.
Cheers all.
Also, does anyone have buckets I can buy? Otherwise I gotta order from Partsouq?
Share this post
Link to post
As a rough guide the USDM 04 sti manual says intake is  0.0079 +0.0016 / 0.0024... so your intake clearances are well within that.
The exhaust clearance is much bigger than 0.010 on this engine though... 0.0138±0.002, the +/- 0.002 is probably pretty good,
so 0.13 and 0.14 is probably on the big side. I have quite a few spare buckets, let me know what you need.
1 person likes this
Share this post
Link to post
Hi Loren
I've always thought that the exhaust is 0.010"?
Are these engines different to the usual then, at 0.014"? Gee this is super confusing!
If that's correct, then 5 of my 0.011" are out, whereas the 0.014" and 0.013" is fine since the range is 0.0118" and 0.0158"? (0.0138±0.002)
Yes I will need some spares thanks, will need to figure out which ones need adjustment..
Share this post
Link to post
I don't know what a BP5 Legacy GT should be...  I know that GC8 STi had 0.008 and .010 and that is what mine is set to.
The USDM 04 STi has the 0.0138 clearance... I have never found any JDM manuals... only USDM. In general though,
.008 and .010 is very common across lots of motors. 0.010±0.002 is 0.008 to 0.012... so 0.013 is too big. You could
look for a specific manual for you car of course and maybe the larger clearance is fine.
Share this post
Link to post
I see, I don't even know where to search for the manual...
So many variants and being JDM it's pretty rare?
I'm gonna keep my intakes as they are, and will keep my 0.011" exhausts the same.
That leaves the 2 x 0.013 and 0.014 as you've mentioned.
Looks like I'll need 2 x 5.00mm, and 1 x 5.03mm bucket.
Measured with micrometer!
Do you have any that'll suit?
Share this post
Link to post
I don't know why it's hard to find jap spec manuals... maybe they are all in Japanese and google only looks for english manuals by default?
I will look through my buckets and see if I have any to suit.
Share this post
Link to post
Yes please can you check ASAP, otherwise I'll order some from partsouq?
Share this post
Link to post
Sorry for the delay. The closest I have is a 499, a 501 and a 502.
Share this post
Link to post
Hiya, thanks for the reply.
Are these measured at 499, 501 and 502?
I can make do with all 3 of those as I've found a couple more out of spec, and those will push some of mine closer towards 0.010" clearance.
Will still have to purchase a couple from partsouq.
Let me know?
Do you have a contact number?
Share this post
Link to post
I haven't measured them and I don't have a micrometer.
Share this post
Link to post
Followers 0
    • Steve
      Anyone going to Automania Auto festival tomorrow up at North Shore events centre?
    • Steve
      Does anyone else on here know or own one of the crouching tigers?
    • Matty t  »  gotasuby
      Help me please Hi iv fitted a dump valve to my vectra c 19 cdti 150 bhp. The 1 I bought was a twinport or receculation valve I don't no just bought and had a go of fitting it my self.  On looking at the car I thought I needed to block the 2nd port so have done bought a t and fitted it on the main intake Of The top Of The intercooler to the inlet on to Of The head.  Ran the bleed pipe and td it in to the on top Of The intake now it's just realeasing through the revs rather than when I lift of it's not because I blocked the other port is it thanks
    • WKDWRX
      https://www.instagram.com/p/BPPX4eLDujb/
    • Gordy Da Hori Hoon  »  RAYDEO
      Hi there,
      I paid online $20: for a 12 months ClubSub subscription.
      I am still waiting to receive:
      A Free ClubSub sticker A Welcome Letter & Membership Card A Discount Code for store items Can this be sorted, please.   Kind Regards,   Gordy Da Hori Hoon.     Hi Gordy Da Hori Hoon,
      Thank you for your order at ClubSUB - All We'll Drive. Your payment has been received and approved.
      — ClubSUB - All We'll Drive
        Order #86
      View Order
        Billing Address
      Gordon Samuels
      2/5 Arawa Street
      Papakura
      Auckland
      2110
        Payment Details
      Status  ✓ Approved
      Method  PayPal
      Transaction ID  3FY28950NY200842S
      Date  04/17/17 10:33 AM
      Amount  $20.00
        Order Details
       ItemTotal
      1 x 12 months$20.00
      Subtotal$20.00
      Total$20.00
