Oil in loom
shady
Hi all hope everyone is having a great Xmas/New Years break.
Who has experienced the oil in the loom problem on avcs cars and what is the best fix?
I have oil in the drivers side loom plug, and on top of the heads. (V8 motor)
Avcs sensors are about 1500ks old
Is this a replace the loom job?
Thanks in advance for any and all help
On October 28, 2011 at 6:16 PM, Guest said:
a special 2 pak resin ( and no I wont tell, as I was the one who has done the research to find out how to fix them and what works and what doesnt )
The resin is used to seal the sensor completely
New orings installed and sensor is tested for correct resistance and insulation
Seems this affects the 08-14 as well on overseas forums so guess the "what did you do to your car today" thread is going to be filled up.
@shady let us know how it works with jbweld
