Brembo Bleed Screw - for Subaru Legacy
Bobby
1 hour ago, boostin said:
From memory they're an odd size and thread.
Odd?
What are you American? They will be metric like most European stuff.
brakes and seats are imperial in lots of cars even if the rest in metric for some very annoying reason.
rallysportdirect.com has speed bleeders to fit, they list them as Sti 02-14 and evo 9-10 so sounds like Brembo have a standard size of m10 x 1.0 so metric 10mm thread and 1.0mm thread pitch. That is the same as the 350z etc as well so must be some options.
7 hours ago, Gripless said:
Odd?
I was more aiming at odd, being different to standard Subaru 2 and 4 pot calipers.
Speedbleeders... The bleed valve on the brakes has a one way valve inside. Normally they are just a hollow tube.
So you loosen the bleeder it doesn't leak immediately, as the little spring in the one way valve stops it.
But once you press the pedal it bleeds as normal, but when you let off the pedal it seals and air can't get back in.
You can bleed brakes without anyone helping. It's like having four of those little self bleeder bottles built it. Still need a but of tube and container to collect the mess and not clover the inner guards. Even if someone is helping still prevents accidentally letting air in.
Cut away picture
Most USA big brands make them. Think those ones are Russell but even edelbrock make them I think, speed bleeders is even a brand.
around usd$7 each but shipping will kill you from most stores over there as its all ups or dhl.
rallysportdirect takes only 4 days even the week before Xmas. Customs will take longer if you get over the nz$1000 mark including shipping.
Group buy to save on shipping? That or one of the sponsors/advertisers of this site maybe able to get them.
  • 2 months later...
Hi All
Sorry for the late reply.
I eventually sourced the bleeder screw from Winger Subaru.
It took 10days to come from Japan.
Bleeder Screw Part no: 26238FE001 - $18.00 excl GST
Bleeder Cap Part no: 26241FE000 - $9.00 excl GST
