Acc displayed 2004 on fuel and clock screen
LegaSubie
weird I was sure it'd been covered here before but cant find it
gogle got me this result so check it out here : http://www.subaruoutback.org/forums/66-problems-maintenance/15509-acc-flashing-information-display.html
Quote
“ACC” in the clock display means there is a problem in the Accessory power source – in other words, the 12 volts that is routed from the battery through the ignition switch ACC contacts.
When the ignition switch is in the ACC position, it provides power to a number of accessories as well as some control modules. In addition to the clock, there's the rear wiper, rear washer, nav system, front wiper and washer. Each of these has a separate fuse. If they all work normally, but in ACC position the clock and radio do not display, then fuse #24 (15 Amp) is the one to look at first. It's located in the fuse box under the dash on the driver's side. It could be loose in its clips, or defective. Or the connector on the clock/info display modulecould be loose.
Also, where did you tie in for power for the Ipod? is it possible that something was affected when you worked on it, but is only showing up now?
P.S. The fact that everything seems to work later, but not when first started in the morning (presumably it's getting cooler at night now in your area) might mean that whatever is causing the problem is temperature sensitive.
