Shibe
2008 Subaru Impreza Lowering, Wheels, other Mods etc
19 posts in this topic
Hey team
Ive managed me score myself a nice deal on a new daily driver which is an 08’ Subaru Impreza 2.0 Manual. Super nice car for the price and really my first decent car that I’ve owned.
I’m looking for advice on lowering the car at some stage, what sort of route to take, easy and sensible options for this car. I was wondering is struts and springs from a WRX or S-GT from the same era would be an idea? I reckon these cars look super nice on a decent set of wheels and a wee bit lower to the ground.
Correct me if I’m wrong but the stud pattern for the wheels is 5x100? Could anyone advise me on the offset of the wheels, etc for when buying aftermarket wheels? I’m not that clued up on them.
and for anyone who has owned the same sort of car, what are some general modifications you did to the car to improve anything from basic engine performance, driveability, servicing, and general things I should keep and eye out for, whether it could be problematic or not?
Any help is appreciated
Cheers.
Edited by Shibe
Share this post
Link to post
I think all subarus use 5x100 wheels. As for the offset my guess would be +55 but this needs to be confirmed.
Have a look at this, it might help : https://forums.nasioc.com/forums/showthread.php?t=2239019
1 person likes this
Share this post
Link to post
Looks like it shares the same wheels as the 08 2.5 Sedan. Mines a hatch but the wheels are indentcle. +55 it is.
Share this post
Link to post
Except for >05 STIs I believe, which use 5x114.3
1 person likes this
Share this post
Link to post
5x100 like Toyota since they own part of Subaru.
offset is high around 50 give or take 5mm. Lower pushed wheels towards outside or car. Also wider rims need offset a adjusted to make them fit.
2004 up sti is 5x114.3
wrx. 2014 up and outback can also be 5x114.3
cheapest option find some factory rims you like with good tyres from a higher model.
i think struts fit with springs, but not springs alone as they are bigger. Some sti ones with lowering springs on trademe.
front may sit high though as maybe designed for more weigh in front with 2.5 and turbo etc.
Smart people will answer soon...
plus non WRX and sti have no rear swaybar so lean like boats around corners
Edited by Gripless
Share this post
Link to post
Oh ok, I learnt something today :)
Share this post
Link to post
Yep I had one of these.
You can fit Wrx/Sgt Struts but not sti struts iirc. I had wrx struts with sti springs but still really high off the ground. I would look for some lowering springs $400-$600 or adjustable coilovers if you dont mind spending 2k. I also put on the Sti sway bar which is a nice little upgrade.
@Gripless I think some come with rear sway bar, my 2008 2.0r came with one. wasn't very thick tho. prob 15mm.
The hatch with lowered suspension with some nice wheels do look sick as...
Another mod is the sti rear spoiler, its expensive for just a mod that looks cool but it does make it look way better.
1 person likes this
Share this post
Link to post
This is excellent. Thank you. Do you think lowering springs on factory struts would ride okay or would it be a tad harsh?
Share this post
Link to post
Im not too knowledgeable on this topic but yes It could be more harsh but on a 2.0r its not gonna be too bad as its so soft for a start. Plenty of people have lowering springs on stock shocks, I have lowering springs on my Sti and its a little bit harsher but I like it. It also depends on the spring you buy, some are harder than others or are progressive springs so it has some tight coils for handling when you get into a corner and some loose coils for comfort.
Share this post
Link to post
The lower you go the harder the ride plus you can't get as wide rims or they tend to rub somewhere.
also the bigger the rims the harder the ride since less tyre to flex and the higher air pressure they use.
also the cheaper heavier rims are worse ride too :(
the newer WRX and sti are stiffer than the older cars since the chassis is more rigid to start.
mine has lowering springs with 18" rims and is like a hitting a wall with any bump over about 15mm open the open road. Not that there are too many like that and it looks good. Most likely it will get higher when I get new suspension at some stage.
Share this post
Link to post
Hmm so maybe just low springs instead of super low..
1 person likes this
Share this post
Link to post
You can always see if a car dealer has already lowered then go test drive it.
it's look vs handling so it's personal preference as to what you can live with.
i want to keep mine as low as it is but the experts tell me it would be better about 20mm higher. Think it's about 30mm drop is ideal.
Edited by Gripless
Autocorrect F*** up
Share this post
Link to post
So I’ve found a set of Impreza RS-R adjustable suspension on trademe for $599 that we’re in an 09 WRX. Surely these would fit my car?
Share this post
Link to post
They prob will (someone else can say) but u will also need to get them certified which is another $500 ish
Share this post
Link to post
That is true. I'm sure I can find some work around for a cert, or just drive without one until my WOF is due haha. It seems like they're an extremely good deal at 599, but yeah best to check with someone else is they fit. The company website that also sells them seems to only have models for Impreza then WRX STI, no standard WRX. so from what i've read on this forum, WRX must fall under the same category in suspension at Impreza as WRX stuff fits in regular ol' Imprezas.
1 person likes this
Share this post
Link to post
If you stack a car on adjusties and have no cert, it will instantly void your insurance. Just something to consider. Also if you get pink stickered it will add a fair bit of expense to the whole operation.
To be honest, adjusties are a S*** idea on a daily.
Share this post
Link to post
No cert invalidates your insurance even if you have a WOF.
atleast when they are cheap the insurance company can accept the cost. You get about 10% of the insured value as mods with most before you have to go to a more expensive performance friendly company.
For 09 up there is no WRX STI, there is a WRX and an STI. Subaru dropped the wrx from the sti to make seperate the sti more which is why the sti was widebody and the WRX wasn't, until they made WRX wide body at the end, I guess to use up the over supply of sti panels.
so it's too hard to tell what things fit without the chassis codes.
Share this post
Link to post
That is a very good point..
maybe just springs then.
Share this post
Link to post
  • Similar Content
    • By Kenian
      Hi Guys,
      So in a mission to find a STI style front lip for my 06 legacy wagon i ended up being forced to buy 5 (Minimum order qty)  - the surplus 4 sold in 30 hours so i have decided to to a group buy as i have found a very good supplier who has well priced stuff for every car under the sun.
      The problem is there seems to be a lot of USDM specific parts around that wont fit us here in NZ but i have spend a lot of time and found some good NZ options.
      My Plan if anyone is keen is as below :-
       PM, email me (kenian.fatherley@gmail.com) or text me (021 1310363) a picture and details of your car or another car off trademe with your EXACT same bumper .  I will send you the options for your car some will have 1 Poly urethane option some will have up to 3 PU and 1-2 Carbon Fibre options.  You let me know which one you like.  I will get pricing from supplier cost up the freight,Duty and GST and quote you a fair price.  If we agree on a part you like and a fair price i will setup a trademe auction for $50 buy now so you have peace of mind that im not just going to keep you $50 and not deliver.  I will use the $50 as a deposit and i will pay up front for all the parts with my own money.Ill then do all importing donkey work, shipping, customs clearance, duty and gst payment etc.  We will have to wait 25-32 days for goods to get into NZ and get through customs.    When all parts arrive here i will send pictures of your specific goods and myself to prove parts are physically here and are undamaged (if any goods are not supplied right or broken/damaged i will refund $50 deposit and take up the issue with supplier myself)  Once balance of payment is received i will dispatch goods accordingly or you are welcome to come to my home (east auckland) and collect.
      I am prepared to take all the financial risk and will not be looking to make a huge profit here - enough to cover the cost and a small margin for my time and finance - any goods that are not good quality or turn up damaged i will take that exposure and return your $50/deposit.
      Please feel free to find picture of lips or parts you like and i will try an find them at a reasonable price - my day to day job is procurement and logistics so hunting Asia and Europe for clients is an 8-9 hour a day thing for me so please send through a pic of what you would ideally like.
      Hope we can get some stuff in at good prices and get some Clubsub members cars looking dope!!
      Kenian
