axle117
BR9 aftermarket stereo back to factory: HELP
14 posts in this topic
Few years back we bought my wife a 2010 BR9 legacy Jap import and came with a dreadful kenwood aftermarket stereo.
Long story short, I found a subaru legacy factory 'NZ new' stereo that came from a BR9 off trademe.  Met the guy and saw the car it came off so know its not stolen.
Plugs into our car perfectly and ran for 20 mins before it turned off and says "security".
I know that the original car has the code hand written in the factory log book but the guy I bought it off hasnt got it.
Is there any way to by pass this code? or disable it?  I can prove its not stolen.
@Subirex Automotive any ideas??
1 person likes this
Share this post
Link to post
Have you called Subaru with the original cars plate or chassis number and asked if they can get you the code?
if it's NZ new they should have a record of it or be able to reset it.
Share this post
Link to post
No, are they able to do that?  Ill call them tomorrow or next week.  That would be great if they could.
Share this post
Link to post
They should be able too, haven't ever tied with Subaru but other brands do.
just act dumb give plate only (you are dumb and don't know what a chassis number is. Cars is for transport not fun), flat battery or some crap and can't find the book (husband lost it rant goes well here). If the missus calls it usually goes faster.
Same way if they serviced the cars and the stereo needed the code they'd have to get it.
but since it went for a while it maybe tied to the same security module as the keys and needs to be done at the dealers. Older ones locked up as soon as they got turned on after they lost power.
Winger was always helpful with the Suzuki I had and questions, sometimes Saturday staff are able to help depends who's working.
Edited by Gripless
1 person likes this
Share this post
Link to post
As long as you have the plate (or full VIN, if it's had a few plates) of the original car the code is usually retrievable.
With that said I - I don't know if a flat battery causes the stereo to lock itself in a Gen 5, ours sat without an engine for a few weeks and the head unit was unfazed. It might have some other way of knowing that it's been removed from its original body.
Share this post
Link to post
For anyone else write your stereo code on the inside of one of the trim peices or inside glove box in vivid, then it's always in the car.
But unlikely a thief will take the unrelated trim. Actually who steals factory stereos they are usually junk.
Share this post
Link to post
I'm not aware of NZ new having security codes on radios. Maybe have CAN communication with BCM?
Where are you? I've not long had the factory radio out of the Mrs BM9 if you want to try that?
Share this post
Link to post
That was my thinking too. Who would steal a factory stereo.
I’m in Auckland (Howick).
I read somewhere that the stereo talks to the ecu and if it isn’t the original it locks it.
Is it an NZ new stereo?
Share this post
Link to post
This is interesting,have been wondering if I can get an NZ new mcintosh to replace the unit in my BR9...
Share this post
Link to post
Actually if you have the wiring diagram you could disconnect the Canbus or data pins and reset the stereo by removing the power overnight. They might fail to working rather than locked.
may be too late given it already wants the code.
other option is @boostin could compare the serial number on the stereo to the default code he has, sometimes they are just part of the serial number.
Share this post
Link to post
So I plugged the stereo in, it didn’t ask for a code for the first 30 mins of driving, stereo then turns off asking for a code. I unplug it and leave for 15 mins, plug back in and it goes for another half an hour before asking for a code.
Yeah if @boostin could have a look at his serial number and code to see if it lines up that would be great. Or if you know even how to punch in the code??
Share this post
Link to post
9
had this issue couple years back when i was at the dealership. stereo doesn't come with security code from factory but the owners can choose to put a security code as some of these are security enabled stereos. there is a way to bypass those using select monitor with a special code. i did this once only and im pretty sure i have the code written somewhere. long shot but if you can make your way to the shop, i can check if my scanner can crack that code.
Quote
i might also have a stereo that you might be able to try
2 people like this
Share this post
Link to post
Cooool!!!
ill pop in on Monday.
Thanks!
Share this post
Link to post
Yeah NZ new. Removed to fit a unit with Android Auto and reverse camera input. I'm in Waiuku.
Share this post
Link to post
    • Steve
      Hi all. So I've just seen on Facebook about a thing called The Gumboot rally it's on the weekend of the 7th of April. Goes from Hamilton somewhere down to New Plymouth then across to Taupo and also includes The Forgotten Highway which is an awesome road to drive, as I have done it a few times now. If you are interested go have a look on Facebook should be a fun weekend I reckon.
      Stay safe on the roads over this time there are some CRAZY people out there who only think about themselves!!
    • Steve
      Anyone going to Automania Auto festival tomorrow up at North Shore events centre?
    • Steve
      Does anyone else on here know or own one of the crouching tigers?
    • Matty t  »  gotasuby
      Help me please Hi iv fitted a dump valve to my vectra c 19 cdti 150 bhp. The 1 I bought was a twinport or receculation valve I don't no just bought and had a go of fitting it my self.  On looking at the car I thought I needed to block the 2nd port so have done bought a t and fitted it on the main intake Of The top Of The intercooler to the inlet on to Of The head.  Ran the bleed pipe and td it in to the on top Of The intake now it's just realeasing through the revs rather than when I lift of it's not because I blocked the other port is it thanks
    • WKDWRX
      https://www.instagram.com/p/BPPX4eLDujb/
