Subru
Getting tune... Guess the numbers
54 posts in this topic
@evowrx Though it was both, but that post was meant to be pretty generic.
writing S*** to explain without lots of terms it is pretty long without pictures and I'm not saying I'm good at it or that it was complete.
Plus aren't early Subaru pistons just cut with a square bowl and only the edge was flat, nothing as bad as Honda etc.
Share this post
Link to post
Thicker HG will affect both CR and quench, you're increasing the volume of the combustion chamber.
Yep even a lot of aftermarket Subaru pistons are a (rounded) square bowl.
@Inked it means you're effectively running a sliiiightly higher compression ratio, so it just means you will, in theory, require less boost to generate the same pressure on the power stroke.
1 person likes this
Share this post
Link to post
Have you got a dyno sheet for it?
Seems like a heap of boost to make that power even with knock. Chris knows better than all of us, but surely that figure could have been achieved at a lower boost level which could have meant a somewhat cooler charge allowing more timing.
Mine gets 190 with a peak of 17psi and is infact down to more like 14psi at that point.
Share this post
Link to post
yes ill post the dyno sheet hopefully tommorow. Yeah 4 more psi only got me 13kw lol
Share this post
Link to post
    • Steve
      Hi all. So I've just seen on Facebook about a thing called The Gumboot rally it's on the weekend of the 7th of April. Goes from Hamilton somewhere down to New Plymouth then across to Taupo and also includes The Forgotten Highway which is an awesome road to drive, as I have done it a few times now. If you are interested go have a look on Facebook should be a fun weekend I reckon.
      Stay safe on the roads over this time there are some CRAZY people out there who only think about themselves!!
    • Steve
      Anyone going to Automania Auto festival tomorrow up at North Shore events centre?
    • Steve
      Does anyone else on here know or own one of the crouching tigers?
    • Matty t  »  gotasuby
      Help me please Hi iv fitted a dump valve to my vectra c 19 cdti 150 bhp. The 1 I bought was a twinport or receculation valve I don't no just bought and had a go of fitting it my self.  On looking at the car I thought I needed to block the 2nd port so have done bought a t and fitted it on the main intake Of The top Of The intercooler to the inlet on to Of The head.  Ran the bleed pipe and td it in to the on top Of The intake now it's just realeasing through the revs rather than when I lift of it's not because I blocked the other port is it thanks
    • WKDWRX
      https://www.instagram.com/p/BPPX4eLDujb/
