Aftermarket head unit.
Subru
You buy a new trim panel that replaces the factory radio and makes it standard DIN sized (the size of all aftermarket radios). Most give you double DIN which is a stereo and pocket or touch screen size.
Most likely from overseas as they sell for crazy money here.
then you buy a pair of loom adapters. One goes from can to ISO standard, the other is ISO to the brand of stereo you buy. They are about $20 for both, even repco and supercheap have them.
If you have premium audio them you need to do some more stuffing about bypassing or inter grating the factory amp.
Or you buy the trim and go nuts putting in a tablet and connect it to an amp and diagnosistic port so you get all the engine data onscreen.
You won't need a trim panel for your car @Subru, it is already double din sized. If you move to a single din radio then you can just buy a single din pocket to fill the other half. The factory support bracket should be fine.
As for wiring you can either buy two loom adapters Subaru->ISO and ISO->whatever brand of radio you buy, or you can look up a wiring pinout and just crimp/solder the correct wires from the car to the loom supplied with the radio.
The loom adapters are easy and plug and play but you end up stuffing an ugly, bulky ball of wires behind the radio. I prefer to crimp join the wires but both methods are fine.
