BC/BF diff in a BG5, Will it fit?
agent
Ive had a quick search around the forum but I haven't been able to find a definitive answer.
Will a Diff from a BC (or BF) bolt into a BG5? Will the BG5 driveshafts fit etc?
I am aware of having to match final drive ratio with the gearbox. Need to find a 4.444 diff to match a V4 STI gearbox and they are proving difficult to source down here in the South Island.
Thanks in advance.
Pretty sure the rear covers have different length studs, but you can use the rear cover from your existing diff.
Driveshaft/diff yoke bolt pattern can also change so check that it matches before buying.
Unsure about axles, majority are the same if you are sticking with the r160 I believe (which you are by the sounds of it)
