Hi Clubsub noob here,
Maroon '96 bg5 legacy twin turbo 5sp manual... my dream car :)
Always driving away from 1st cold start of the day, (with couple minute warm up) start driving and gets up to 2500rpm and feels likes it's labouring from then with what looks like vapour out the exhaust (more than usual hot exhaust on cold mornjng). Back it off its OK,  2500+ labours with vapour again, until temp gauge is at operating temp approx 3-5min of driving then everything comes right and will be right anytime later.
Is there a typical or a "not unheard" of thing where primary turbo has a warm up period, a moisture spit from pipes that's gathered overnight, a gummed up cold idle spring that's not returning fast enough, possible head gasket that starts leaky and comes right when warm. No water or oil loss though... so bit stumped.
Only while beginning of driving 1st start of day where it's been untouched overnight, so 1st thing in morning or afternoon in heat of day but not previously started and run to operating temp earlier that day. If it's been driven to work at 5.45AM (it'll do it then), but it'll be fine at 3.45PM later on way home. It's like the overnight period of cool down makes the difference.
Any tips appreciated.
Kind Regards,
Nic
Hi Nic,
My car is similar, it has a bunch of vapour/steam or whatever coming from the exhaust and definitely seems slow (off boost) for a few mins in the morning and then its fine, I think its pretty normal especially in winter. Im sure someone here can tell us why. Its probably happening when your idling too but you just cant see it in drivers seat.
If you are in traffic in the morning, you can sometimes see other cars vaping and drops coming from the exhaust too.
Hope that helps
It could be an o2 sensor on the way out or plugs? o2 sensors wont heat up as fast in the winter so it will be running in open loop for those first 5 mins of driving you described. At that point its probably super rich and thus bogging down.
Good explanation as to what o2 sensors do and how they work: http://www.autotap.com/techlibrary/understanding_oxygen_sensors.asp
My V7 was a bit of a turd when cold as well, doesn't do it now that I've aftermarketed the fook out of it.
It's probably one of 2 things... the heater coil in your O2 sensor is a bit F***ed so it takes a while for that to get up to operating temperature, or your coolant temp sensor is a bit S***.
