Subaru v7 pvc bypass or plumb
Hi everyone im new here the names kiwinui but you can all call me kiwi..any whoo I was wondering if any one can help me out with the pcv system on my 2002 subaru wrx sti ej207...sooo I'm a bit confused on different views and setups that people run, some say block the intake side of the pcv also cap the end off on the block side will this do the engine any harm?also dose the pcv have to tee in to tub of duct?any help would be much appreciated also pictures of setup would be great..I plan on running a catch by tee'ing head breathers together..last question what is the breather next to the head vent hose and what can be done with.. sorry for the lengthy write up just want to cover everything..reason why I ask because I'm in the middle of doing a flipped intake manifold and looking for other clean looking options..
  • 3 weeks later...
I removed mine on my old bc5. Plugged it with a fitting I had laying around. You could cap it ect too.
Won't harm anything, but it's there for removing the crank case gases I believe. So you would need to look into a catch can system.
pro tip a catch can system is more than just a catch can, proper systems have oil separators in them so when you're holding high rpm for long periods the oil can go back into engine rather than overfilling your catch can. If you do any sort of racing or extended thrashing you will need the full system. If it's just a daily driver you will get away with a simple catch can system but will need to keep an eye on it.
