romeyromes
Learned Values Help!
21 posts in this topic
Hey everyone
I need help reading/understanding my learned values.
I am using an OBDlink LX with BTSSM.
I have no clue what I am looking at and I have a hunch that my car is not feeling too good lol.
Thanks in advance guys :)
Share this post
Link to post
What fuel are you using and what mods?
The top line tells you the most in this case. IAM should be 1. Anything less means there’s been enough decent knocking to justify a global ignition retardation. Jap imports will sometimes sit at around 0.9 or slightly less if driven hard purely because NZ 98 is still worse than the jap 100 they’re originally tuned for.
In the fuel correction section the last row (40.00) is the only one of concern. The 2.3 means the fuelling is off by that much in the last zone the ECU can adjust for based on the o2 sensor reading. After that it bases it solely on the tune. This means at full throttle your fuelling is off by 2.3%
In general, a positive at higher g/s ranges means more fuel is being added as there is more air in the engine than has been calculated for. So there is more than likely a leak before the turbo, but after the airflow meter.
The turbo inlets like to split so that would be a good place to start looking at a guess.
The timing correction section (does the same as IAM but tweaks things in certain rpms/loads rather than over everything) isn't too bad currently. Imagine as soon as the IAM number raises more will show up in that area.
All in all you should definitely be getting it looked at.
3 people like this
Share this post
Link to post
Thank you! That makes total sense actually.
I've had a subtech downpipe installed and I use 98 from mobil.
The intake piping before the turbo seems warped and I noticed some oil there too. I'll completely remove it this weekend and observe it better.
Edited by romeyromes
1 person likes this
Share this post
Link to post
So after a wee bit of driving last night and my drive to work this morning.. below are my updated learned values.. Bizarre or ??
2018-08-29_09-38-34
1 person likes this
Share this post
Link to post
Have you reset the ECU?
It takes a shitload of time for the ECU to slowly raise the IAM by itself and it would do it incrementally not just straight back up to one.
2 people like this
Share this post
Link to post
I had my car serviced on Monday. Didn't ask if they touched the ECU but they may have.
Sent from my F8332 using Tapatalk
Share this post
Link to post
Encouraging it to knock isn't the best way about it but it may be worth resetting it again with BTSSM and then driving around for a few days as you normally do to see where it settles back to on its own
1 person likes this
Share this post
Link to post
Cool will do.
So with the latest LV I posted, would it be fair to say that my car is relatively happy?
Or should I still see someone?
Share this post
Link to post
Does it still feel like it's not driving well?
The fact it got that low in the first place means something was, or still is quite wrong. A reduction that significant doesn't just happen for no reason then dissapear
Share this post
Link to post
Thanks mate,
Yeah I am. I have this very intermittent stumbling issue that I cannot pin point hence me going with BTSSM.
I'm getting crazy lean fluctuations on my afr too.
Would a weak fuel pump be the culprit? Or perhaps my warped turbo inlet?
Share this post
Link to post
How many km’s on the car?
Both do fail, turbo inlet is a lot easier to diagnose and rule out really. Get a mechanic to do a smoke test if you’re not confident digging around looking for potential leaks yourself
Share this post
Link to post
I'm 80% confident it is the turbo inlet (but I've been wrong about my car plenty of times lol) because of the oil residue seeping. Oil blow by escaping?
It has done 130,000
Share this post
Link to post
Oil being in the inlet is a given unless you have a catchcan. Should be residue, not really a pourable amount.
Sounds about the right KM’s for it to be a possible failure point.
Share this post
Link to post
Yeah no catch can and the oil should stay in the inlet and not outside?
Time to call strong for Subaru lol
Share this post
Link to post
Pretty much yeah. If it's sealing properly the inside will be coated but should have nothing on the outside
1 person likes this
Share this post
Link to post
Okay, so my IAM numbers dropped again after a drive last night and has remained the same this morning.
I'm new to this logging stuff but I'm going to have a go at it today.
Below are the new values. Is it fair to say that the high-ish figures in yellow indicate I am running lean?
Share this post
Link to post
Also, I set my knock event alert to -3 and no events registered
Share this post
Link to post
If it's removing fuel (which to me a negative % correction looks like it is), that means it's reading rich. An inlet leak after the maf would create a rich environment.
I know nothing about the software you are using, so could be reading it wrong
Share this post
Link to post
Excuse my ignorance, all of this is new to me.
May I ask how it would read rich if there is a leak after the maf? That would mean more unmetered air going in which should read lean?
Share this post
Link to post
Sorry, i'm thinking in a pressurized pipe (post turbo).
You are right, a leak post maf - pre turbo should cause it to run leaner (which to me those values don't suggest, but I could be reading it wrong)
Share this post
Link to post
