Legacy ECU wiring Diragram
skdtime
I’ve got an 03/4/5ish service manual pdf that has all that stuff. Wouldn’t rely on it 100% though. Not even sure what country it is for other than that it has 90% of what i’ve needed, and the 08 one i’ve got gives me the other 10%.
It's a good place to start and then confirm wire colours at sensors, then engine bay main connector then at the ECU itself. I’ve spent hours doing that for mine so far.
What are you needing it for?
A family friend whos a mechanic is working on one of these cars and theres some test he wants to do with his multi meter to test the pin for the battery recharge or something like that. Im not fully sure what it is but something along those lines. Anything to do with the ECU would help.
If you think its fairly similar to the H6 ECU thatd be a lot of help.
