08 sti harry
Best at home diagnostic tool
I have a 08 sti. I'm not looking to tune or anything just want to know what's a good diagnostic tool and where to buy. Just want to be able to read and clear fault codes and that sort of thing
Share this post
Link to post
A Tactrix cable connected to a laptop with is a decent idea. Not as cheap as some options but can do a lot more if ever troubleshooting faults.
Or BTSSM if you have an Android device. Normal 08 JDM STI’s are supported but you might want to double check that yours is compatible
https://www.btssm.com/?page=app
Share this post
Link to post
Any cheap Bluetooth one should work with android to read codes and live data.
iPhones need the wifi ones they are still cheap compared to the tactrix
tactrix can program the ecu as well.
i got mine from jaycar at a high price just as I couldn't find my USB one and it was Sunday with check light on.
Share this post
Link to post
If you're ok with spending about $300 on a scan tool, you can get a small Launch one from AliExpress.
I would highly recommend Launch, as that's what the shop I was working at used 99% of the time for scanning cars.
If you want live data etc, I'm guessing you'll need to spend more (or less).
But if you just want to read codes, and clear them, and want a good tool for that, Launch.
If you're wanting to scan Euro stuff with a Launch tool though, good luck. My experience was like 50% success.
Share this post
Link to post
Well the jaycar one works fine on 08 sti and android which is $69. the Ali express version is cheaper.
The software has to work with the car and adaptor as well its a three part combo deal.
for $300 you'd better get the tactrix one.
those costly Chinese ones are mostly the low tech skill all in one versions for workshops where learning and playing around is a waste of time and money.
the older pre 98 cars are not obd2 from memory so need different adapters for obd1.
F*** I just realized I now have an iPhone and have to do all this S*** again...
@08 sti harry where are you based?
Share this post
Link to post
Ok 3 different wifi obd2 adaptors on the way for NZD $64 yay China and 40% off sales B|
stupid Apple not supporting Bluetooth correctly :CEL:
Edited by Gripless
Share this post
Link to post
G-Scan 2 is what I use, not what I would call cheap ( NZD12,000) but will connect to anything and give you the options to that the bluetooth ones don't :)
Share this post
Link to post
I'm based in chch I'm gonna start with a cheap ali express one If that doesnt work the btssm seems to have pretty good reviews
Share this post
Link to post
Join the conversation
Reply to this topic...
  Only 75 emoji are allowed.
  • Similar Content
    • By Subru
      Recently I have gotten a grinding/squelching/scratching noise coming from front left of car when turning right or if I yank it left. Its gotten worse and worse over last 2 or 3 days. When im driving while slightly turned left its fine. Happens at all speeds and increases in frequency as I speed up. Its not a clicking so doubt its CV/Axle. I could be wrong on that tho.
      I have wiggled wheel vertically and no movement from wheel bearing or strut however there is a little movement when wiggling it horizontally and the movement is coming from the rack, just a little play I guess. Cant see any stones lodged anywhere near the rotors/pads.
      Would like to know what everyone here thinks it could be. Ill prob take it to mechanic tomorrow if I cant figure it out.
      This video im turning left and right (noise is when I turn right). May struggle to hear without headphones.
      At slow seeds.
