Single din in 03 legacy wiring
iludez
So I have an 03 bp with the factory stereo and HVA ea single din cubby which fits a single din in nicely. I've taken the factory one out and tried to figure out the wiring. I thought I would just be able to splice into the factory harness and run the headunit off of that, but it turns out that doesn't seem possible when I do try splice into it I just get terrible crackly sound and its very low volume. Anyone got an idea?
  • Get ISO harnesses from TM/Repco/Supercheap etc - Subaru to ISO and ISO to whatever stereo you have
  • Unplug your factory stereo - separate plug, HAVC is on a completely separate plug so won't be affected
  • Connect your new stereo using harnesses
  • Connect aerial (might need an adapter - available on TM etc)
You obviously won't be able to use your factory stereo anymore.
Damn I was hoping I could just splice the wires. When I disconnected the stereo harness the air con screen didn't display though?
