Weird Issue! Need help
iludez
A vac hose blown off gives symptoms similar to what you're describing. Typically runs better when at high revs/loads then will struggle hugely at idle/low load.
I’ve blown my BPV hose at the manifold end a few times now. It isn't barbed at all and hard to get a hose clamp onto. Not an issue with a front mount as it’s a 2 second task but not quite that easy with a top mount in place.
Give it a bit of a tug from the BPV end and see what happens
That's actually what its doing, at 100 its fine but low rpm its wanting to die and pretty rough till past 30ish.
BPV as in bypass valve?
Like the hose on the stock bov on intercooler?
Yea. Or any other vac hose, the BPV one is just a common one.
If it was me, with the gear I have, i’d pressurize the intake which will straight away hiss like crazy if anything has come off. A mechanic with a smoke machine shouldn't have much trouble finding one if it's there.
Could be anything that effects individual cylinders if it's not an air leak. Coil pack, spark plug, injector. Normally it’ll drive like crap even when loaded up with those issues though, hence the vac leak theory.
At idle the leak is a large percentage of the expected airflow but once at 100-200g/s it'll reach the peak it can flow through the small hose which will mean the expected airflow is off by a considerably lesser percentage which is why it doesn't feel as bad.
Thanks mate
