Cut wire help!
axle117
Hey team,
Iv had my type R for a while now and pretty must know it inside and out EXCEPT I have just recently found a wire that the previous owner has cut and I was wondering if anyone had any info on whether it’s meant to have a plug on it or if it’s meant to be attached to something?
I realise this is a hard question but if any who has a version 5 sti could pop their head under their steering wheel and see what’s up. It’s right beside the black and green plugs. I would love to see if it has power but the car is currently out of action.
Pics attached.
Is there a second black plug dangling under there? I’m guessing it is the other half of the black ecu reset plug.
Edit: Just checked on my v6, the two black wires were tied up with factory tape. I pulled them out so you can see. They have pins on them but they aren’t the normal, diagnostic/reset plug wires so I’m not sure their exact purpose. Not supposed to connect to anything by the looks of it though.
Edited by IZichard
19 minutes ago, thewabbit1 said:
Could just be grounds? get a multi meter and check the voltage difference between them and a known 12v. Or see if you can test for continuity across them and the chassis.
EDIT: just re-read @axle117s post, saw car is out of action. @IZichard do you have a multi meter handy?
I have one but it is at work. I could check it tomorrow if needed, but they aren’t connected to anything and my car has always worked fine so I don’t think they are particularly important.
My guess is some test/flash wire for the Subaru factory. They were taped up out of the way inside the factory loom tape.
That looks exactly like them. Wonder why they had their pins removed. Anyhow, I’ll clip them short and tuck them out of the way like you had. Once the car is mobile again I’ll test for any power.
Cheers guys!
