Impreza EZ30 Swap
Subru
I have been thinking (again lol) about an EZ30/36 swap in an Impreza/wrx body.
Done some research and seem like its a case of finding an EZ30 with gearbox, modify wiring to suit the body to the engine, aftermarket ECU(?) and modify radiator location.
I assume there would also be other stuff like fuel pumps I may need to upgrade too.
Has anyone had experience with a swap like this and is it as easy as it sounds? I like the idea of being able to do a swap by myself with basic tools and not needing a shop to make custom mounts etc.
Maybe have a chat to possumborne. Not sure how much of the build they did but they had a late model one that was converted to a H6 just recently up there. Was going for big power so imagine the build price was extraordinary.
What's the end goal? Adding a turbo to it or staying N/A?
You’ll be talking a fair bit of custom stuff To get things fitting since a H6 has never been offered for an impreza. Not sure why you’d need a new gearbox, your current 6mt will fit up to it.
I was not thinking about my car. I was thinking about a gc gf chassie impreza and just having an NA H6 in there. Nothing too special.
Im not sure if the factory gearboxes from the 1.6-1.8na gearboxes will handle the torque of an H6 unless I could find a wrx or sti with no engine.
@Joker cheers ill take a look tonight.
5 minutes ago, Subru said:
Yeah MCM's was in a legacy with a turbos and and stuff. That build was pretty cool.
Marty's daily - SuperGramps.
It's a EZ36 with a Garret turbo (can't remember turbo model).
This guy in NZ did a EZ30 out of a BL/BP Legacy with a 6 speed into a old Impreza wagon.
Runs a Link G4 ECU. Few videos on his channel about it.
I seriously think you should consider this swap though... 13B Impreza 9_9
If you are totally seriously, you need to do the BL/BP EZ30, because of the 3 exhaust port heads and AVCS that the BE/BH (first gen EZ30) didn't get.
I've always wanted to do something similar, but BP wagon manual, Centrifugal Supercharger, FlexFuel, and thats that. Be a wicked daily/road trip car in my opinion.
Edited by Individualities
Haha 13b wouldnt be difficult or expensive xD. Would be cool tho lol
4 hours ago, GC8E2DD said:
I was thinking a little GC Impreza with a plain old EZ30 w/factory ECU would be a fun daily driver. And pretty good on gas. It doesn't need to be a rocketship drag queen.
I was thinking the same, a whole bunch of torque everywhere and no lag with a nice 6 cylinder exhaust noise to go with it, perfect daily.
Even my Sti is a bit annoying to daily because its just warmed up when I get to work 15 mins away so I have to baby it the whole way off boost. :(
On 11/19/2018 at 6:04 PM, Andy_Mac said:
The older single ex port BE/BH 3.0’s should work a treat on a stock ECU. BL/BP ones are considerably more complicated and would need a crap tonne of electrical know-how to get running without a Link, if possible at all...
The guy in NZ that did the BL/BP EZ30 swap into a GC chassis used a Link G4+. Mind you, that car took him like 5 years lol.
The EZ30 from the BL/BP is more complicated due to having AVCS (& AVLS?) on the intake cam. Plus it has Drive By Wire Throttle and all that economy stuff, that you basically remap to be like a cable throttle.
I've thought about doing this swap myself, into a BH Legacy - kinda like @whitebait19's Lancaster, but with the BL/BP EZ30 and a 6 speed.
Seeing that beautiful car around town a fair bit doesn't help with the temptation too :|
A mate has done it recently into a bc5, took him a month or two but knows what he is doing and has the tools.
Made a radiator top joiner/cross over pipe so he could use a factory rad, seems to be working.
Link g4 extreme, wired using factory engine loom and link a/b looms
Falcon throttle body (bolt on i think), unsure on what throttle cable he used.
Still not cheap.
Still not cheap.
Which EZ30 did he use? The first gen (came in BE/BH), or 2nd gen (BL/BP)?
