Headlight clearing
HannesNel
I used the Mothers NuLens stuff. Did a great job.
Comes with 800, 1200 and 3000 sanding pads, PowerBall and NuLens clear plastic polish.
Have a nosey in my Garage thread (in my forum signature) if you're curious.
I know guys here have done the multiple grit wet sanding, Clear, then wax.
Probably the only thing I can think of is to use an Enamel Clear (someone correct me if you should use Lacquer).
I've used the RainX kit which sounds similar to the kit above, and its great, but the tiny sanding pads clog so quickly it becomes kinda hard to use.
I'd consider purchasing 3 big sheets of sandpaper for about $1 each and some headlight sealer. Probably similar price all up but it will last you longer.
Exactly. Wet sand paper too. That way the paper doesn't clog up as fast. The 3000 grit pad in the NuLens kit is basically like a fine scotch brite pad.
 Yup, nice - much better way to go about it now that I've purchased the entire kit.
  • 4 weeks later...
  • 1 year later...
On 26/02/2019 at 9:08 PM, swamp said:
I did my girlfriend's ford festiva headlights with 180g and 240g and cut and polished, turned out alright but would advise using finer grades after to get rid of scratches. Would be satisfying on yellow as hell lights.
How long did it take you to polish the 240g out? I would've thought something like 1000 grit would do the trick.
I used some rainx headlight restorer, its not great but atleast my headlights aren't so yellow anymore and it only took 15mins. If they are really bad, wet sanding would be the only way...
