Intercooler Water Spray - Auto Button Trigger?
8e4r
Hey guys, just wondering if anyone knows what is required for the 'Auto' button intercooler water spray to trigger? A few Subaru forums point to the ECU controlling this (unconfirmed). Does anyone have more info on how this works and under what circumstances (e.g. from x PSI boot & y intake temperature etc.)?
Specifically after info on how this works on the GCs, as it may be different on the GDs and newer.
Cheers.
the ecu controls it
it can use a few inputs like rpm, temp,boost, speed etc and then based on conditions it will spray
the sprayer can be tuned to suit
usually if im doing a reflash on stock top mount, i will make it have more aggressiveness the spray
unsure on the GC8 parameters but thats what the GDB has above
On 12/12/2018 at 10:16 AM, Pappu1 said:
the ecu controls it
Thanks! I'll have a chat with the guys at PBMS when I get the car tuned.
Edited by 8e4r
Fairly sure the GC auto spray was pretty basic, something like based on throttle position (which is pretty useless imo).
If you're getting it tuned on a link or the likes, you could hook the sprayer control to an ecu output and have the ecu control it based on just about anything.
I would have thought air intake temp and speed would be a good place to start?
the older pre v5 GC were more basic
i think in the v5/6 GC they added a few more smarts
the GD got a lot more smarter and better
the GR onwards went back to being pathetic with no spray except for the single spec c version .. what a pity they missed the spray on the GR/GV models...
older  &quite neat write up on these ( and a DIY kit to build your own)
http://www.autospeed.com/cms/article.html?&title=Intelligent-Intercooler-Water-Spray-Part-1&A=0527
and from near the bottom on Page 1 is this table
Quote
Summary of Conventional Intercooler Water Spray Control Approaches
Control Technique
Advantages
Disadvantages
Boost Pressure Switch
  • Simple, cheap
  • Relatively late switch on
  • Switches off on gear changes, even when driving hard
  • Switches off on trailing throttle, even when driving hard
  • Operates even when intercooler is cold
  • May be on continuously during high speed cruise
  • Wasteful of water
Throttle Position Switch
  • Simple, cheap
  • Early switch-on
  • Wasteful of water
Intake Air Temperature Switch
  • Operates only with high intake air temps
  • Will continue to operate during gear changes and on trailing throttle
  • Simple, cheap
  • In urban driving can be on continuously due to radiator heat soak, lack of engine airflow
  • Very wasteful of water
Boost or Throttle Position switch plus series Temperature Switch
  • Can have early switch on
  • Depending on system dynamics, can be wasteful of water
I stumbled on this too during my Google searches, nice read!
Will update this topic if I find any concrete information, cheers for the responses everyone.
i have done the following in the past :
set a boost switch to a timer circuit.
that way the spay continues a few seconds after the boost event (gear change)
set the boost switch to low trip (say a few psi)
in an additional step, you can add a temp switch that only allows circuit activation on higher intake temps (saves on some water)
but the initial setup (despite being hard on water use) is good for a all round spray setup that works well
