• Announcements
    • 1randomkiwi
      ClubSub Forum Updates   13/03/19
      Important forum upgrades are coming up which may mean the www.ClubSUB.org.nz forums will be temporarily unavailable.   Check out our Official Facebook Page for more updates.   www.facebook.com/ClubSubNZ
Niran
Bucket Seat Recommendations
23 posts in this topic
Hey guys.
At my last track day, I was flying all around my factory seat in my GVB 2011 STI Sedan. Cornering was hard, trying to stop myself from sliding away plus focusing on driving lol.
Have you guys got a any recommendations for a good bucket seat? I know nothing in this area yet. Good / bad brands etc.
Not after a hardcore racecar life seat. After one that is still comfortable and adjustable, but still keeps you nicely locked in on a track day. If such even exists?
Share this post
Link to post
Recaro.
Try locating some GRB Recaros, make sure you test-sit in them first as they seem to be designed for an average size Japanese person i.e pretty tight :)
1 person likes this
Share this post
Link to post
haha yeah for sure @sobanoodle
Have sat in a the GRB recaro. Its pretty good! Ideally want a little more bucket than that if possible?
Share this post
Link to post
Racetech dude, fixed back seats but no reason why you cant leave the seat on a mount and swap it for track weekends. I would never look back after getting one its comfy to drive to and from the track, FIA approved so you know its safe plus it supports local business :D
2 people like this
Share this post
Link to post
road recaros like grb and cs etc are ok for road use but on track they don't hold you well.
go for a fixed back seat like the above racetechs or sabelt, sparco etc.
new if you can afford it.
buying used can bring big savings but can also be like buying a used helmet.
caveat emptor.
2 people like this
Share this post
Link to post
Cheers guys! Definitely more inclined to get a fixed back one. How do the rails work? Do you need to find a subaru specific one that works for each brand? Or will any of those sparco / racetech seats fit into my current rails?
Share this post
Link to post
Thought fixed-backs would fall under this category :D
2 people like this
Share this post
Link to post
@sobanoodle i'm clearly showing my lack of knowledge on the subject here hahaha
Guess by hardcore racecar seat i mean uncomfortable to drive in the weekends, and 6 point hardness etc.. lol
Edited by Niran
1 person likes this
Share this post
Link to post
It's going to be hard, if not impossible to use the 3 point belt with a proper race seat... possibly not allowed in schedule A.
I do not think schedule A allows the use a 5/6 point harness without a harness bar any more either.
1 person likes this
Share this post
Link to post
Buy seat
Decide if mounting to 1) bottom exclusively or 2) bottom and side of seat
Buy chassis specific rails if either 1) or 2)
Buy side plates if 2)
Something like this
Share this post
Link to post
1 hour ago, RaKid said:
Buy seat
Something like this
Or cut chassis rail mounts out and weld in new mounts that match the new seat brackets directly... no rails to worry about.
Share this post
Link to post
I got the side mounts from Racetech with my seats and then got some rails from Scarles they seem fine and are able to pass cert so do not feel that they are 'unsafe' it does add up to be a bit but highly worth it in my opinion. if you were going to leave the fixed back seat in I would recommend hard mounting it for less movement though which I am doing now.
Share this post
Link to post
@Gripless
You had a harness for yours with factory seats mounted to the isofix points in the rear seats I believe?
How did that compare to stock / a real raceseat?
May be a cheaper and easier option for Niran
Share this post
Link to post
Yeah factory seats are great running harnesses.
but only if you have a HANS device. Which you should have anyway and at $600 are so much cheaper than they used to be.
otherwise there is nothing to stop the shoulder straps closing around your neck as the stock seat has no middle divider.
Harness bolts are the international imperial thread all seatbelt use so replace the rear seat belt bolts. They come with many belts for free.
you need to buy a longer bolt to replace the front belt in the bottom of the b pillar.
isofix is a tiny metal rod for baby seats.
If you want a seat spend the extra on the newer racetech. They are better curved at the back and way better for comfort.
Edited by Gripless
Share this post
Link to post
Harness with a non fixed back seat sounds like a terrible idea imo.
Share this post
Link to post
Harnesses without a harness bar on a cage isn't a great idea really. The belt angles arent good.
But then running a half age does take the rear seats away.
Share this post
Link to post
Not if you dont have any to start with! Although it does take away my access ot the fuel pump without dropping the whole tank...
Share this post
Link to post
Racetech RTROAD if you plan to leave it in all the time. Probably still work with a 3-point belt due to reduced wing height.
RT4009 if you're going to remove it when you're not tracking it.
For the money you can't go past a Racetech. Don't bother with the japanese stuff like Brides, they are made for pencil-width people. And skip any off-brand stuff, NZKW etc are probably not heinous but you get a lot more pedigree for a few hundred $ by going to a Racetech.
2 people like this
Share this post
Link to post
Also the airbag in the seat makes daily use a pain to get cret as you have to get OEM tested rails.
ive got recaro ones signed off in the past so it can be done.
@Niran I'll try to remember to bring my belts to the dyno day and you can have a try
Edited by Gripless
1 person likes this
Share this post
Link to post
Shot thanks team. The racetechs do look very nice. Just need figure out how to get em installed now :)
1 person likes this
Share this post
Link to post
How tall are you? Would have thought you'd be on the cusp of maybe being too big for a 1000 seat based on their site.
Share this post
Link to post
https://www.racetech.co.nz/shop/seats/national/RT4119W-WT-seat
cost more but that new design is so much more comfortable.
plus if you have to add hundreds for the cert agian the seats are all expensive.
Or daily the lower sides are so much better to get in and out of when in car parks and you can't fully open the door.
https://www.racetech.co.nz/shop/seats/club/RT4000WX-motorsport-seat
1 person likes this
Share this post
Link to post
