iludez
Wheel bearings!
43 posts in this topic
So my wheels bearings are on the way out by the sounds of it. Whining/high pitched noise increases with speed.
How hard are these to change out on the front? Never done this before and not sure I'd even have the tools to be honest. I assume ordering from partsoq would be the cheapest? And I have to change the whole hub part?
Share this post
Link to post
easy to do if you buy the whole hub and bearing assembly, just did both my wagon front bearings. Its in my thread if you want to see photos of things apart. I got my bearings from SubTech in Penrose
Share this post
Link to post
So I'd need to buy both hub and hub carriers?
Share this post
Link to post
this
Image result for subaru legacy bp front wheel bearing
Share this post
Link to post
this
So that's the hub and carrier or just hub assembly?;
Share this post
Link to post
Hmmm just jacked car up and checked left front wheel for any play and there was none vertical or horizontal..... Took wheel off and had a look but couldn't see anything out of place. It does sound like metal on metal so I can't think of what it could be does the noise from about 20khs and gets louder with speed.
Any ideas?
Share this post
Link to post
Whats the milage, one of mine went at 120,000 and so I just did both. Mine sounded pretty metallic and rumbly..
Share this post
Link to post
220 on body. It's really whining/ mettalic sounding. it's almost like it's the center diff bearings? Can't get it looked at till next week so it's a bit scary having to drive it around it's not super loud but is definitely noticeable
Share this post
Link to post
Silly question, but it's not your brake pads being low?
Don't think so to be honest look to be still pretty high on tread
Share this post
Link to post
Center diff bearings make noise from middle of car by shifter correct? Sounds like it's coming from left front wheel area
Share this post
Link to post
Checked right side wheel and no movement I do have an audio clip but it's pretty hard to decipher anything lol
Share this post
Link to post
From my experience wheel bearings have to be pretty shagged to get noticeable movement when working the wheel by hand. Also often its the opposite side than it sounds like O.o
Share this post
Link to post
Ah ok sweet so it could still be bearings you think?
Share this post
Link to post
Id suggest so, just not sure what else it would be.. its the easiest thing to change too. Getting stuck into diff bearings is no fun and its also less likely than a wheel bearing
1 person likes this
Share this post
Link to post
Cheers man, yeah my initial thoughts were wheel bearings both probably shagged. Didn't think it would be diff as it's from the front no noise at all on top of trans or in cabin really at all
1 person likes this
Share this post
Link to post
Dumb question maybe but it's not RPM-linked is it? I got some horrible whiney grindy noises when the bearing in my alternator belt idler failed.
1 person likes this
Share this post
Link to post
Pretty sure it's not rpm related but more so to speed. There is no noise when idling which I assume would be the case if it was altenator?
Share this post
Link to post
If the bearing is squeaking it's usually because it's seized completely and the outer shell is rotating in the hub.
No rumbling because the bearing is not actually moving at all. It will wreck the hub pretty quick when it gets
to that stage. You should be able to move the wheel though... if not by hand, then with a crow bar under the tire.
Or it could be the brake pads.
1 person likes this
Share this post
Link to post
The wheel was very solid when I tried moving it both ways. Just the usual movement in the wheels no play that I could feel. But doesn't rule it out noise is 100% coming from upfront, I'm way more leaning towards being bearings again because it's only around the wheels I can hear the noise. I'm going to have it looked at and see what they say. Have hubs and bearings lined up if it is them
Share this post
Link to post
Uhhg is it brakes? I feel so conflicted on what it is.
Share this post
Link to post
Does it go away when you are on the brakes?
Undo the hub nuts and see how loose the bearings are then.
Edited by Loren
Share this post
Link to post
Nope doesn't change with braking. Undo the actual 32mm hub nut?
Share this post
Link to post
Yes... or just loosen it off... if the hub nut is on super tight it can prevent any movement in the bearing, even though the bearing is rooted.
Share this post
Link to post
