borland667
Impreza STI v3 yellow injectors question
7 posts in this topic
USD 184.60Hi Guys,
I was wondering if there is a plug and play replacement for my Impreza sti v3 injectors (yellow side feed). Also, anyone knows for sure what's the flow rate? I've been reading different information everywhere and I couldn't get anything from the manufacturer. In fact, I'm not even sure what's the manufacturer for these ones!
Some people say these are 440cc, others 480cc and a whole other bunch of people say 550cc (Part # 16611AA231). I wanted to replace them with new ones but these are quite expensive (USD 184 in jp-carparts and USD 134 in partsouq, each!) and hard to get. Does anyone know a direct replacement that can be used? or perhaps a rebuild kit? or any ideas on a replacement for these ones without breaking the bank!! LOL
Cheers guys!
Share this post
Link to post
Do you need brand new? Second hand sets show up on trade me and facebook etc all the time - https://www.trademe.co.nz/motors/car-parts-accessories/subaru/engines/listing-1940788646.htm?rsqid=0fa015542855424290915ef1a7c15363 for example.
You just need phase 1 injectors (like the ones in the auction) as the phase2s wont fit. I *thnk* you can tell em apart quickly as phase 1s have single holes whereas phase 2s have 4 holes in the injector.
Share this post
Link to post
You can also get adapters to run phase 2 injectors to open up your options a bit. Or just change rails.
Share this post
Link to post
Cheers guys, I'm thinking about going with the adapters for opening up the options a bit...
Share this post
Link to post
You can get bolt on OEM remanufactured stuff on TradeMe too depending on what cc you want.
Share this post
Link to post
Thanks!!! I'll keep that in mind!!
Share this post
Link to post
Fairly sure the factory yellows are 440cc @ 80% IDC and 550cc @ 100% IDC. You can get aftermarket 880cc side feeds.
What are your power goals?, if you want factory "new" injectors i'd have thought 2nd hand side feed yellows would be cheap and get them cleaned/flow tested
1 person likes this
Share this post
Link to post
  • Similar Content
    • By Subru
      Recently I have gotten a grinding/squelching/scratching noise coming from front left of car when turning right or if I yank it left. Its gotten worse and worse over last 2 or 3 days. When im driving while slightly turned left its fine. Happens at all speeds and increases in frequency as I speed up. Its not a clicking so doubt its CV/Axle. I could be wrong on that tho.
      I have wiggled wheel vertically and no movement from wheel bearing or strut however there is a little movement when wiggling it horizontally and the movement is coming from the rack, just a little play I guess. Cant see any stones lodged anywhere near the rotors/pads.
      Would like to know what everyone here thinks it could be. Ill prob take it to mechanic tomorrow if I cant figure it out.
      This video im turning left and right (noise is when I turn right). May struggle to hear without headphones.
      At slow seeds.
