Brembos off a Legacy
TNHSTI
Adaptors for the rear calipers, unless it is a tbSTI which will have the correct rear backing plate and larger handbrake setup. Which you'll want to grab.
The tbSTI ones can use standard v7 rotors but if you use adaptors you need either thicker handbrake shoes or the adaptor rotors from DBA which are quite pricey.
Fairly certain the brake lines are the same from memory. Might be worth just grabbing them too if they are braided ones
ok cheers so the brakes on the wrecked ones are oem  without adapters so I will need to also get the rear backing plate and handbrake setup?
