• Announcements
    • 1randomkiwi
      ClubSub Forum Updates   13/03/19
      Important forum upgrades are coming up which may mean the www.ClubSUB.org.nz forums will be temporarily unavailable.   Check out our Official Facebook Page for more updates.   www.facebook.com/ClubSubNZ
StrokedEJ
Rollcage install
29 posts in this topic
Hey guys due to getting ban from the track I am in need of a rollcage. This is new to me and unsure what to do. Good shops to go to, cost, certs etc
Sent from my SM-G950F using Tapatalk
Share this post
Link to post
Going by your previous posts, you're Auckland based right?
Share this post
Link to post
Do you need a full cage or just the roll bar half cage?
if it’s a half cage you can just cert it via LVVTA.
Full cage requires licence and money
1 person likes this
Share this post
Link to post
Not sure what I require. If this helps the cars fully road legal an I use it couple times a week weather its cruise or short drives. I use for odd drags and track days like chrome flat nats etc etc
Ray Chubb. He's built plenty of roll cages and does them to a very high standard.
https://www.rollcage.co.nz/
Cheers I'll check it out
Share this post
Link to post
WIf you need a full cage then you need a Motorsport authority card which makes it road legal and no LVVTA cert required.
Ive has both in cars and were done by road rally race, Ralliart. I was lucky and got one done by a guy over here from Ozzie Supercars looking for extra work.
Cromolly cost more and can’t be repaired if you bend it.
also the handling changes with a full cage and the chassis flex vanishes.
https://www.nzdra.co.nz/images/downloads/NZDRA-RuleBook-2018.pdf
Section 5.63
Edited by Gripless
1 person likes this
Share this post
Link to post
You would need a 6 point at minimum but in your case to keep the car road legal you require a 8 point which goes to the front strut towers. You just go get your MSNZ licence then apply for a authority card no cert required.
3 people like this
Share this post
Link to post
What Inked said is the best practice.
If you've seen the likes of @RaKid's engine bay, and you want quality work (Not saying the others suggested aren't at all) then BD Motorsport is a place I'd recommend. A close friend of mine who used to work for them, and is now working for Cameron Racing in the states for GT stuff, says their work is top notch and Ben is really good at his stuff.
3 people like this
Share this post
Link to post
If you go forward through the firewall find someone who’s done the Subaru before. Ie go ask the rally guys. The last place I when had templates for all the cuts in the body so it looked great.
Rally places may already have something they have planned and ready to bend up fast.
2 people like this
Share this post
Link to post
There is also a place in CHCH called NZ rollcages and they pre bend kits for you, example a half cage kit shipped to wellington is $290.00 incl.
Could be good to look at then you just need to find someone who can weld it up
2 people like this
Share this post
Link to post
Cheers yep will take a look now. Thanks for the help.
Share this post
Link to post
31 minutes ago, Loren said:
Can NZDRA cages be used at MSNZ events?
I know that some years ago the answer was a resounding no - you could go run a 10 second pass with a super ropey half-cage made of exhaust off-cuts arc-welded together in your mates garage and that was more or less fine, but MSNZ would laugh at you if you tried to get the cage homologated.
6 people like this
Share this post
Link to post
From a quick look while I was at a conference today. That nzdra book says  you can use it for both provided it is cromolly. And meets both standards.
Also has something like sub 9.90 is full cage,  11.00 is half based on a what the chassis is.
Msnz cage youll have to do two club level events a year to keep it legal.
Youll need to read both books and talk to a couple of shops that do drag and rally as forum world isn’t gospel
1 person likes this
Share this post
Link to post
9 hours ago, StrokedEJ said:
ban from the track
I'm slightly interested in these circumstances, more info?
Even Playdays have the prestige 'class' which can be as 'dollar efficient' as committing to a cage
Share this post
Link to post
If you run sub-11.0 you aren't allowed to run again until you have a cage (half-cage?).
1 person likes this
Share this post
Link to post
Oh right hah Drag Strip can be called a race track too huh :P
yeah I'm jelly and old
Share this post
Link to post
If you're not worried about getting it homologated for circuit racing and only want to do drags, you only need a 5 point half-cage. Good for up to 10.00 sec.
Seeing you're Auckland based (Meremere), NZDRA does not apply as they adhere to IHRA rules. Go to section 3.61 and you can see the diagram they provide.
http://www.meremeredragway.co.nz/files/MDI_Track_Rulebook_6AUG18.pdf
You will also need an SFI approved crank pulley, fixed back seat, harness bar and harnesses, shield plate over top of the transmission in case of flywheel exploding, drip tray underneath engine, etc. List goes on.
Worth talking to an IHRA tech inspector before you start.
1 person likes this
Share this post
Link to post
Ok does that change again if we go lower than 10.00. As were going for the 9z
2 people like this
Share this post
Link to post
Going for 9s you need a 6-point.
We're on the road to 9s as well, although as the car is still mainly street-based I decided that we're going to do a 5-point half cage to keep minimal bars in the car. If we get kicked out then I'll still be happy that we've run a 9.
Edited by itsmitchlowe
1 person likes this
Share this post
Link to post
You got lolgtr
Share this post
Link to post
Aw yep how much power an boost yous run on that 10. What was your 60fts with thos slicks?
Share this post
Link to post
Road tuned, 1.85bar pump gas. 1.66 60ft - need to play with suspension
Share this post
Link to post
